Another starter question...
Bend, Oregon
So, I decided to swap my starter from a '70 FJ55 into a'77 FJ55. (starter in the '77 is toast and I am waiting for a replacement, so this is temporary anyway) Bolts up great but the orig. '77 starter had an extra bolt on the end for a wire connection. Um, I am not to bright so I was wondering if anyone can tell me what that wire is for or how to make it work?
I have read quite a few starter posts (while searching) but have not quite figured this out. I do not have manuals in reach and have not looked up schematics on-line yet. Is this just a ground? It looks too fancy to me.
First pic is the '77 starter with the extra post and the second pic is the older starter without the post. I pulled the wire off the old starter and was going to add it to the temp. starter but do not know where to attach it. Ideas?
Thanks, Carlos.
Interesting...typically the older starter that has been in service with a points and condensor type ign system would have a 3rd connection point like that. The purpose was to give a full 12v feed to the coil during start up only. Once started voltage would flow into the coil via the ballast resistor. I wouldn't have thought a 77 would have that set up or need. Anyway, I would say definitely not a ground and it would be easy to test if it sees only 12v on start up only. Put the tester on it and have a buddy crank it over. Also, you said you had a wire connected to it ? What was the color scheme of that wire ?
Edit
Went into the links section and saw this for a 78
http://www.yankeetoys.org/documents/wiring_diagram_78_fj40.pdf
It appears that they still employed the 12v on start only wire in 78 (BW off the starter going to the coil).
Well, I just tossed the old starter on the '77 and the same noise/thing happened when I tried cranking it over...A loud click and then nothing. I did not bother to connect the extra wire-just to see what happened. I have tried bridging the gap between posts while the old starter was installed and nothing. Engine did not turn over and so I thought the old starter was fried and therefore I needed to replace it.
All this happened without warning as I was driving down the street. The rig stalled just before an intersection and has never started since. The starter that I thought failed had only been in place for a few months (remanufactured crap I thought, but now I am not sure what is wrong!) I have swapped out batteries and cleaned battery terminals, I guess I need to check the ground wires as well. It seems that both my pigs are missing ground wires from the starter to the frame- or maybe I did not notice them upon initial inspection. WTF!?
Here is another pic. The '70 starter I plan to use is on the left (without extra post) and the other is the old/reman. '77 starter with the extra wire and post on the right. Wire can come off easily but I do not know where to attach on the other starter???
Thanks for the help, Carlos.
Oh yeah, the wire is black/red with an attached clip that mates to a wire taped along with the pos. wire from the battery. Does not seem to be a ground. I installed the 'good ' starter without connecting this wire and no dice-same noise as before. It does not seem like just a slight clicking noise. Actually sounds like the starter is really tring to do it's job but is somehow seized, or (please say no) the flywheel is...
What condition are the battery cables in, and how are the connections to the battery and ground?
Sounds to me like a loose wire someplace.....
Good luck!
-Steve
If you think that the engine is stuck, put it in 4th gear, and try and roll the engine over by rocking the truck....If the engine is stuck, it will not move...
The exact same thing just happened to me 2 days ago
Went into work +(on my day off) for a lame meeting.
on the way home a mile into the return trip. Jackson stalls like the feul stop flowing. Friend tows me from the middle of the street to a parking lot.
We try sparking the coil wire no spark. We figure it must be the Ballast resistor or the coil.
Next day
Ordered ballast resistor arrives. No start
Buy a new Accel coil had an msd before still no start.
So being that it is 8 p.m. very windy, cold and dark. Plus I am more than a little bitchy, I call it a night.
So there Jackson sits waiting to move under own power once again.:confused:
bonzai...that's a horse of a different color than Lucy's problem. With your ign turned "on" are you getting 12ish volts to the + side of the coil. I say 12ish because you do have your ballast hooked up.
Yes I am Battery is getting low though
Going to look again for any loose or detached wires. Gotta warm my hands back up first
So, I too thought about engine being locked up...I am going out to check that (and of course I am freaking out). I am going to better inspect, maybe even swap battery cables and stuff and to check the wiring. Have to clean my grounds also. I cleaned the battery terminals and posts and swapped in a good Optima battery. Still no luck. Geez, I hope its a wire.
Thanks everybody! Wish me luck, Carlos.
Yes definitely clean up all your grounds. Even when they look all right sometimes they are not. Gotta rule out the easy stuff first anyway. Hoping it's just a ground........
Hmmm, I do not have a ground going from my starter to the frame, in either of my rigs, but that seems to have been the case for years and they worked fine before all of this. So I have to get a hunk of wire and make a ground. I also found a wire that had come undone that was taped to the pos. battery cable and it appears to go from the coil to the starter. Hopefully fixing both these things will help me out.
I wanted to confirm about checking if the engine is seized or not. I tried putting the tranny in 4th and rocked the rig but it would eventually stop. It rocked but it wasn't going very far. No fan or belt movement. What do you think?
Thanks again, going back under...
I made a temp. ground out of smaller gauge wire connecting the starter to the frame. I also reconnected the wire taped to my pos. battery cable (I think it is a fusible link).
I tried starting it and the same thing happened as before. Then I put the 'old' starter back in (because I suspect it may not be the problem after all) and the same clicking sound. I buddy stopped by to help diagnose the issue and we tried a few things to no avail. Any other ideas?
I think its time to check my dist. and ignition system...
Doesn't sound like you (nor I) are convinced re: the engine at this point.
"No fan or belt movement."
The fan blade should have rotated some if the engine spun/moved at all. Just me talking here but....I'd pull the plugs out, and put a large socket wrench on the crank pulley nut and give it a turn and tell 100% yea or nay on the locked up motor. I'd also drop the flywheel inspection cover down to see what or if any large bits fall out and hit me in the head.
As an aside..careful where you hook that wire up on the old non extra posted starter. It should only have 12v to it when the starter is cranking.
Thanks toddslater,
So, I was thinking about trying to crank this thing manually also but I do not have a socket or device big enough to fit on the end of the crank. I also have no radio in this rig- could I seize an engine with no warning? I heard nothing and saw nothing prior to or during this fiasco. The truck simply stalled, quit, and rolled to a stop. The end. I guess I should check my oil level and lower the flywheel cover. I peeked at the flywheel when I removed the starter and it looked good so I did not think to check it more thoroughly. Hmmm.
Oh, and I never actually hooked that wire up to the 'new' starter. I just left it hanging. Could that have any adverse effect on anything? I believe that wire/connection leads to the ignition coil. I now have the reman. starter that I thought was fried intalled in the '77 pig again, just for kicks. Everything is hooked up, along with the temp. ground wire and I 'fixed' the disconnected fusible link wires but same results again. Ithought I should use this starter for its 'correct and complete' set-up.
I popped the dist. cap and checked it and the rotor for wear, carbon, anything. Also popped the points sheild to check the points. Everything looks quite new, no burning, no marks, no nothing. I have little use on this rig since last tune-ups. Any other ideas?
Thanks again.
I dunno...my first order of biz would still be to confirm that the crank cranks, the pistons piss, the whole smagaggie spins freely. After that issue is certain, be it an electrical gremlin, POS starter/soleniod acting up or other such nonsense, we can focus on those areas.
With the plugs out, it will be mucho easier when you do the rocking test in fourth (not fighting the compression strokes)...also before I had big mofo sockets, I could put a smaller socket on the alt nut or PS nut or similar, press on the belt so it would not slip, and rotate the motor a little. On one motor I had, I used one of those chain type oil filter wrenches wrapped around the outer edge of the crank pulley to give it a little spin.
One way or another...if she don't rotate...we can put all the starters on the shelf for a while whilst we figure out what locked it.
The distributor will not prevent the starter motor from working properly....
MAKE SURE THE ENGINE TURNS OVER. Put the truck in 4th gear, and rock it back and forth....DOES THE ENGINE MOVE????
If NO, you have bigger issues to concern yourself with beyond the starter not turning the engine over.
If YES, then you need to get your electrical connections between the battery and the vehicle up to speed, as it really sounds like they are far from it....
Post up some pictures of your wiring mess....these wires that you have 'connected to nothing'....that are a 'fuseable link'....
Agian, make sure the engine rotates. If is does not, you do not need to go any further with the starter...for now. You will need to get aggressive with trying to move/rock the truck.
Yes, an engine can lock up without warning.....it is not common, but it can happen....there was a simialr thread here a week ago about someone's engine that locked up while comming to a stop at an intersection....oh, and the whole ' locking up without warning'.....there typically is SOME indication from noise or other signs that the engine is making that things are not correct.....
Good luck!
-Steve
