I noticed a few PHH repairs in the past few weeks. I became a little worried. The PHH on my 80 has never been replaced. I decided I'd rather be safe than sorry and performed the replacement over the weekend.
Much to my wife's dismay...she wanted us to go to the pool...as a family. "You'll be done by the time we're ready to leave right?"...uhm, yeah sure...
I brought some helpers with me...
While it was pretty easy to hook the wrench onto the lower 12mm bracket bolt, it was a bear to actually break the bolt free. I simply couldn't get enough leverage. Problem was solved by hanging the wrench off the 12mm bolt, snaking some rachet wrench extensions so the socket end pushed against the wrench and hitting the extensions with a hammer. The extensions do *not* go through the hole your hand fits in - the angle is too severe from there and the wrench will get pushed off when it was hit. Instead snake the extensions from a few inches over to the right (they go in between the tranny lines). Then hit it with a hammer.
The pieces...
The old PHH doesn't look half bad...
The new hose is silicone hose from NAPA. The only place to buy decent clamps, w/o calling around, appears to be West Marine. The clamps are ABA 316 stainless steel ones. The threads are pressed into the clamp body, so the inner part is smooth. Pricey buggers...$4.60 a piece.
In all, parts were around $15 for the two clamps and six inches of hose.
Install was pretty straightforward...although I wish I had tightened the clamps more before installation. PITA to tighten them when they swing around the hose.
A little patience was required to tighten the lower bolt on the metal pipe, but really it wasn't too bad. Only about 10 minutes spent.
Finished product:
The pieces...
Finished product:
