If the typical pressure settings on a CO2 regulator are in the order of 150 psi (see Jody Potters Tech info on DIY CO2), and the maximum pressure range on air tools (e.g. pneumatic impact wrench) is around 90 psi, then do you have to have a separate regulator for each application? Or just have to plan on inflating tires with a lower psi from the tank?
