Another locking diff light question
Boise Idaho
Hello all, I have another question regarding factory locking diff dash lights on my '97 LX 450...I know this has been beaten to death in the past but I can't seem to find any specific info on my particular concern. I have confirmed that my center diff and rear diff are actuating and locking but the rear diff dash light still flashes. I used jack stands in the rear and engaged the cdl button with the rear diff lock button only and the rear wheels are definitely locked solid. Is it possible the internal actuator switch has lost continuity? The front locks in and the light goes solid as it should when using the same test technique. Thank's for all your input.
It may not be engaging fully, enough to trip the switch. The switch may be bad or a wiring issue. Test for wiring, switch contact, etc with an ohm meter
Yes, it's very possible for the indicator switch on the rear actuator (or the front) to stop working. Mine doesn't work for the rear locker, the dash light just keeps flashing. It's not an issue to me, as I know the diff lock is working. I'll get around to fixing it when I dive into the rear axle for something else someday. The only time you have to worry is if the center diff lock indicator switch stops working, as that will keep either of the axle lockers from actuating.
-Spike
this happened to me too, test your switch, if you don't know where it is I can send you a pic, let me know.
My rear locker was engaging because I could hear it, tested the motor with a 9v battery and made sure it was getting juice from the ecu, but the damn dash light was still blinking.
Take the switch out and test the continuity of it with a multi meter when it is engaged. If it is not allowing current to go through clean it up and spray a little electric parts cleaner into the tip and leave it over night. Then test again.
This did it for me and the switch worked after I cleaned it up. If yours doesn't work you may be able to get a used one, or ask cruiserdan how much a new one is.
There was a thread on here that I remember an aussie who drill a small hole in his to spray the electric parts cleaner. You may give that a shot if after a couple of days of spraying it in the tip doesn't work. You have nothing to lose but a bad switch.
But make sure it is your switch first before you try any of this.:beer::beer::beer:
I had the same problem with my indicator light for the rear locker. It's the connections in sensor I think. Take a piece of electrical tape and place it over the light. I used 3M but I imagine other brands would work too.
Diff Lock Switches
You can check to see if the diff locks are actually working by jacking up both wheels on one side of your truck. Don't forget to chock the other side. with the key in the on position but without the engine started and the trans in neutral engage the center diff and the operate the switch for the rear locker. Turn the rear wheel until you hear/feel the diff lock engage. It will be very obvious when it engages. The same process can be used for the front locker.
The Diff Lock Engaged switches are known for giving problems. I have had some luck with using contact cleaner to dislodge the crud from inside the switch.
Here is a link to a post I wrote on the switches.
https://forum.ih8mud.com/showthread.p...ff+lock+switch
Good luck
Geography
FYI New Zealand is NOT a part of Australia.
So I would be a Kiwi not an Aussie!
Cheers
Is the center locking up?
If the center does not lock then it stops the F&R from engaging.
There is a sensor on top of the TC towards the front that has been the culprit of this before. It send the signal back saying that the TC is locked. Its $55.
Did you do the 9V actuation on the center as well?
That actuator can get messed up do to breather issues some have mentioned. I have not had that problem, at least yet.
Diff Lock Switches
You have to wonder if people actually read what you post.
You stated in your first post that you have confirmed that your center diff lock is working and that the rear is working as well just not the switch.
And still people write suggesting that you check the center diff actuator and switch.
Have fun
Hedley
Hedley
LOL, it's a hazard of forums. I catch myself doing that sometimes, skipping some key information in the post and making an ass of myself with a reply that's totally off-base. No biggie. :D
-Spike
