Romer said:The switch is activated but the locker is not fully engaged(My guess). Did you try driving it a little?
RavenTai said:If you know it is locked then likely the switch has gone bad, there are several of theses same style switches under the 80 many have had success taking the switch out cleaning them out. If not they can also be replaced,
before I did that though I would make sure it is locking but the light is not activating, jack the rear axle, turn the key on and lock the center and rear lockers, turn one rear tire until you hear the locker snap into position and check that the wheel no longer rotates.
Still no solid light? pull the plug from the switch and jumper the two pins on the connector together, got light? Then switch is bad fix or replace.
slick621 said:I am going to try that as well. But, is there a "wire" that connects at the diff that recognizes that it is locked?
