So we just picked up some 2850J's and 2863's (non-J) used as a set to go into my dad's '93 80.
From what I've read the J's in front and non-j heavies in the rear give the rig a relatively level ride.
I do have the OME heavy kit in my 95, which has the same rear springs but smaller fronts. For caster correction I used the ca77 bushings. The shocks are 60018 in the front and 60020 in the rear.
So a few questions:
When using the J springs in front, we need to pick up larger shocks and use more caster correction than just the bushings, correct? I'm thinking caster plates like the ones from Slee, and 60018 or 60070L shocks for the front.
The rear should be the same as in my 95, with the same springs, so we shouldn't need to mess with the upper arms to get an acceptable drive shaft angle, right? For the rear I'm thinking either 60020 or 60071L shocks.
Which would you use, L's all the way around, L's only in the front, or the 2.5" 60020/60018 shocks?
So when using L shocks, you need to add bump stop spacers in order to prevent over compression? From what I've read, this would be the only disadvantage to using the L shocks.
Is the sd24 steering stabilizer a necessary addition when adding a lift, or can the stock one be used?
Helpful thread about the lengths, but not much about what bump stop/caster mods need to be made.
OME shock length just doesn't make sense!
Thanks, any insight is appreciated!
So a few questions:
