Another CEL / OBD question
Ohio
Greetings - long time no post. I'm new to the OBD discussion (and yes, have used the SEARCH tool here). My model is a '96 Cruiser, the 10th VIN digit is T (1996), I have the 'DIAGNOSTICS' port on the passenger-side firewall in the engine bay. My hood sticker says "OBDII compliant". I went to AutoZone to have them read why the CEL was on. Neither I nor they could find any OBDII port, so they gave me a line about "since it's a late-95 build, you might have to take it back to the dealer to read the code." I left thinking that wasn't exactly right, so I looked further. TADA! I popped the fuse-box plate off (beside & below the steering wheel) and I believe the OBDII port is there. Am I right about that? If so, what's with the port under the hood? Am I one of those "partially compliant" vehicles? The CEL was on about 6 mos ago, mechanic thot it was catalytic converter failing. He cleared the code & about 5 months later it came back on. If it is the cat, they can be expensive to replace. Do you guys replace them? Go aftermarket? Thanks in advance.
the port is in the fuse panel
Need to be more specific on your code, what code was it?
I am guessing its a type of emissions code like a p0401 or p1033 or other. If so, these are typical with the age of the truck and fairly easy to fix yourself and not to expensive or the dealer will charge you an arm and a leg to do it for you
Typically either O2 sensors, EGR or VSV if an emissions code. After you get the code, do a search to find a wealth of information from people who are where you are today and what they had to do to fix the problem, don't forget to post back up what you did because we like to hear the happy ending.
FYI - it's code P0420
Romer, thanks again for the help. Per AutoZone, it's code P0420, which could be: 1 cat. converter defective (possibly due to reasons 2,3, or 4) 2. Engine misfire or running condition 3. Large vacuum leak (possible gas cap thing) 4. Engine oil leakage into exhaust-valvue guide seals, piston rings.
I'll look around & re-post once I nail it. -Potbelly
I had an intermittent P0420 code. Replacing the exhaust gaskets (2) at the cats did the trick for me. Cheap and fairly easy (had to torch out the old bolts).
Id just change the O2 sensors and order new butz as well. You can get a good discount from cruiserdan. Look up the number for American Toyota in the link in the top right, support our vendors
