whoa nelly...
dude, the cross caster is more than .5. bearings will effect camber readings, but not caster by much..
caster will only be affected for the most part on a radius arm vehicle, by either the frame side mount, the tube, or the mounts to the axle tube. You would have other symptoms besides the pull if your bearings were toast enough to cause this issue.
The bushings alone could cause this though. The problem with taking this to a shop is that according to the specs, the caster is not adjustable on these vehicles, so your tech is not going to be trained in it. If you are not doing this yourself, you would need to get the install specs, and have them verified or re-done by the shop. Something I believe books something like 4.0 hrs.
I would then recheck once those are verified that they are in correct.
On most hunter racks, it is not possible to get the cross caster without doing a full sweep, but he could have placed it wrong, like landtank says.
Most shops also offer a 30 day guarantee on all alignments, so use this to your advantage.
Why did you bring it in to get checked? Did you tell them it was pulling, or did you just do this as "maintenance" for tire wear?
