I'll apologize upfront for posting yet another Caster thread, but I guess every truck and solution looks like it is different. So, here's my situation and my thoughts on what to do about it. Feedback from the Caster Gurus will be appreciated!
First off, here's the current malignment readings. The truck has the OME 2.5" Medium springs in the front and OME CC bushings installed correctly per OME's instructions.
Measurement Feb.7
Caster, Left Front 0.7*
Caster, Right Front 0.1*
Front Cross Caster 0.6*
Camber, Left Front -1.3*
Camber, Right Front 1.6*
Front Cross Camber -2.9*
Toe, Left Front 0.05*
Toe, Right Front 0.01*
Total Toe 0.06*
As you can see, my Caster is just about nil. I'd like to get it to at least 2*. I do not have the Toyota control arm bushings so I'm seeing if I can figure out a caster correction solution utilizing the OME bushings and something else.
I like Landtank's method of pivoting the axle on center versus simply tilting it but I also figure his plates are hard to come by. Also, I am not adverse to using MAF's drop brackets as I don't think I'll be doing anything extreme enough to overly worry about the brackets dragging. Unless there are other reasons to avoid them?
So, on to my question--would any of the following combinations be appropriate to get the caster to the 2* to 3* range? ANd what do you think the implications would be of combining them?
1.The OME bushings, Landtank's bushing template, and Landtank's plates;
2. The OME bushings, Landtank's bushing template, and MAF 3" drop brackets;
3. The OME bushings, Landtank's bushing template, and Slee plates.
I'd prefer not to have to grind, etc. to make things work, but if the best solution involves that, I will do it. I just want it to be done correctly and right. If that means having to pony up the cash for different bushings as well, so be it.
Thanks!
Brett
Measurement Feb.7
Total Toe 0.06*
Thanks!
Brett
