Another carb question
Pa.
I kinda? messed up my 1/74 Aisan carb.(Don't ask) I had the vacuum advance port on this carb. I friend has a rebuild 11/72 Aisan still in the box.The 72 carb doesn't have the fuel return line.What I was going to do,was take the bottom of my 74 carb off (vacuum advance port) and put it on the 72.Can I also take the fuel return line off the 74 and put it on the 72, or should I plug the return line?
Thanks!
If you have a question about carbs, shoot Jim C. a shout. He's FJ40Jim on this site.
Good luck!
Well it worked!!!! I switched bases of the carbs,then hooked up the return fuel line on the 72 carb,and all is well!! It's running great right now.I've decided to go back to the stock exhaust manifold and be done with header issues. Thanks for all the help!
