Another carb question
Yucaipa, Ca
Sorry to ask... I have a 76 FJ40 with a 78 carb. All smog equipped. It runs great, quick start ups, no hesitation or smoking. My problem lies with the idle. Idle consistently is around 950, but if I apply a slight upward pressure on the gas pedal, it drops and stays at 650 until I start accelerating and then I have to do it again when I stop. The mechanical linkage has no visible slop. What might be obvious to some of you has me perplexed. Any help would be appreciated. Thanks. One more dumb question. When turning the fuel mixture and idle speed screw clockwise, are you leaning or enriching the fuel?
The mixture screw trims idle fuel. So clockwise would be less fuel, counter clock would be richer or more idle fuel.
You could unhook trottle linkage from the carb. This will tell you if the bind is in the carb or linkage assembly.
If you post pics of your setup someone might spot the issue.
I had a similar issue recently. The vertical link, that connects to the gas pedal is adjustable. I had to shorten the length to allow the accelerator linkage to completely close. It’s an easy adjustment. It pops on and off with little pressure. Back the nut(s) off and twist the threaded rods in or out. If yours is hanging up and causing the increase in idle, try to shorten that part of the linkage a bit. Good luck.
Thanks guys... I performed ANOTHER lean drop adjustment and noticed that the vertical linkage mentioned had come unattached. Not only that, I had it attached in front (DS) of the vertical spring attachment ( hope that makes sense). I reconnected it the correct way (I cheated and looked at photos). Anyway, it leaned up quite a bit ( no more burning eyes at idle) and idles at 650 with vacuum at 17. Just for info, the fuel mixture screw is turned out about 3 1/2 turns (ccw) and the idle screw is out 4 turns (ccw). Thank you all for you thought. Merry Christmas
