Another Carb Question
Arlington, TX
1970 FJ40 with 1974 F155 (or f.5 or f 1/2) engine. Original carburetor rebuilt at some point and modded slightly to work on later engine.
It's been sitting for a couple of years so I want to order carb rebuild kit but I have a couple questions that I couldn't find the answer to after a half hour of research.
I haven't seen the engine run (broken spark plug when I bought it) so I don't know how it runs other than word from PO that it ran well when parked with broken plug some years ago.
The engine has a PCV system installed but obviously the earlier carb needed to be modified to allow that to function.
First question: will a standard 1970 carb rebuild kit fit my needs here?Second question: are there any major differences I need to note when ordering rebuild kit? I see there are a couple of options for 1970.
First photo shows modded PCV return. If it matters, date code is 0D 27.
Use this link to identify your carb and go from there:
Page 042 Land Cruiser Carburetor Identifier
(Thank you, Marv.)
That PCV return location on the carb spacer is original and standard for a 1970 carb. Any kit for a ‘70 carb will work. However, I do not recommend the Keyster accelerator plunger with the rubber end. Use an accelerator plunger with a leather end. I think you can still buy OEM plungers or they also come in the Hygrade kits.
Make sure you cap the brass nipple above the idle mix screw if you’re not using it. Here’s info on that brass port.
If you lack a 10mm port on the topside of the intake, the booster line is next best. That said, the 10/69-9/70 carbs offered a manifold vacuum port in the fuel bowl of the carb. It utilizes the hollow screw that comes up through the throttle body to secure the fuel bowl. Some people would argue that it is not true manifold vacuum at that point, but I consider it good enough for all my needs.
Best
Mark
www.marksoffroad.tripod.com
I just got a carb kit for my Federal '75. It came from SOR with a Keyster accelerator plunger (right). I don't know what happened to the old one (left), but it seems to have lost quite a bit of size with time, and there was no gas in the bowl for what was likely years. Could the old one be made from leather? Could it be good if it gets reintroduced to gasoline?
1970 FJ40 with 1974 F155 engine. Original carburetor rebuilt at some point and modded slightly to work on later engine.
The carb was not modded to work on later engine. The choke bracket was bent all to shiite to get an earlier throttle cable holder on there because the sweatshop rebuilder lost the stock 70-72 throttle cable eye.
Also be aware one wire for the ICS is routed wrong, pinched behind the choke bracket.
Note the following in this pic from SOR.com:
1. The throttle cable eye is in place under the main body bolt.
2. Choke cable bracket is not bent.
3. ICS wires are both on the outside of the choke bracket.
4. ICS does not have a vinyl condom covering up who knows what skullduggery
Yep.
Nope. There are many variants of the keyster kits, because of changes in jet sizes, but that doesn't matter because they are usually not good sizes. The important thing is to get the correct gaskets (which are all the same 70-74).
What month / year is the build date of the truck or carb?
0 D 27 is 1970 April 27.
I just got a carb kit from SOR with a Keyster accelerator plunger (right). I don't know what happened to the old one (left), but it seems to have lost quite a bit of size with time, and there was no gas in the bowl for what was likely years. Could the old one be made from leather? Could it be good if it gets reintroduced to gasoline?
Yes, the old one is leather. Soak it in 5W30 synth motor oil for a day and it will probably come back to life.
Thnks all for the info. Still learning what is right and wrong on this truck as I go here but it's starting to come together.
I'll take off the rubber condom and see what lies beneath. Hadn't noticed that wasn't in any of the other carb photos I'd looked at.
I knew the arm was bent but didnt realize it was not the original choke cable eye. Hopefully I can straighten it all out without breaking anything.
Thanks again!
