- Joined
- Nov 6, 2006
- Threads
- 65
- Messages
- 1,653
- Location
- Boulder County, Colorado
- Website
- www.adventuretoolcompany.com
After several years of using a Solar Shower with mixed results (cold results) I started looking at other systems and found lots of nice options but held off because they seemed a little pricey for what they were. So, like most cruiser owners I fab'd something up.
Starting with a $5.00 kitchen sink sprayer w/hose, $29.00 all steel pump-up sprayer and a left over air hose quick connecter, I put together a 1 gallon pressure shower. It works great for one. You fill it half-way with regular camp water (cold) then boil a pot of water. Add the boiling water, replace the pump, pump it up and you have an instant hot/warm shower for one. Enough water to wet, soap and rinse since you control the flow with the sprayer. It also helps conserve water to 1 gallon per shower.
The longer hose allows you to leave the sprayer on the ground, so your not looking for somewhere to hang anything. The system is compact and rugged enough that it can be packed without worrying about punching a hole in it or having to carry a number of other parts/pieces and since you use your camp kitchen pots and camp stove to heat the water you don't need to carry a separate heating source.
I chose to use the metal pump sprayer because I planned on putting it directly on the stove to heat but decided against it to prolong the sprayer and cut down on any mess...so I'm sure you could use a plastic sprayer also.
Good luck.
Good luck.
