I had a local shop that does a lot of import work service the front knuckles on one of my rigs- a 97 80 series w/ 2” lift via OME springs. I would have tackled it myself, but time for that doesn’t exist for me. After getting it back, it has two issues that I noticed:
1) rumble / vibration only under load / throttle on highway between approx 60 and 65mph. Sounds like it’s coming from up front. Can feel it in DS foot board. Wasn’t present before the front axle service. Shop thinks it is a harmonic noise. I think it’s axle / bearing related.
2) negative camber on front DS wheel. Wasn’t there before the service. Checked it with a level on flat surface of outer wheel. PS is fine. Can see the top of DS tilted slightly inward when standing in front of it.
Because the camber was OK prior to the work and the noise wasn’t present I’m working with the shop to make it right. They are not accustomed to seeing this type of axle. Further, I’ve jacked up the front and there is no noticeable play (12-6 or 9-3) on either side. They replaced inner axle seals, both inner axles due to wear at the seal point, and DID NOT change any bearings because they thought they looked OK. Any ideas on what could be causing the camber issue? Should I be concerned? Could the noise be related to the negative camber on DS? Thanks for any input.
