Unfortunately I can't see the pics on this government computer. Photobucket will do that to them.
I'll see when I get home
I will get the videos uploaded soon, it should tell the story.
Cliff notes on the axle......393W-low-low and 30 spline dana 60 rear on left line. Made it up the rock 3 different lines and tried the left and it broke.
CJ lost a 16.5 tire, little gas and it was back on. Oh, he broke a driver door and window too.
Not seen is a broken Ford 9" on a full size Bronco.
=FUN!!!!
Well you know if you werent driving a Jeep you wouldnt have that broken axle BTW to much skinny pedal will do that to especially in a Jeep, Toyota's dont have that problem we don't have enough power to break Toyota running gear.
Dan![]()
fixed for ya.
Daaaannnngggg!!! Got 'em.
You sure your just not butt hurt because the little ole yota axle shafts are the same size as that D60 of yours that broke?? And the fronts.....hhhmmmm, buy a $800 or so d60 front, or buy a set of $600 chromo shafts for the yota fronts and run them like a mad man......besides, the yotas are smaller rigs, they don't need alot of power. The guy I bought my 3 link rear from ran 42's on it, and it's just a little ole toyota rearend....
http://www.longfieldsuperaxles.com/images/torquetestgraph.jpg
just sayin'..........![]()
Your right, I am going to put my 60s for sale today. Prolly won't sell though cause everyone is looking for Toyota stuff.![]()
I did not see any T****otas up there, you guys seem to do a lot of talking but I have yet to see a T****ota run this trail with out help. I guess you can all sit around and run your mouths because that is easy. If T****ota axles are so strong why are T****ota guys looking for 60/14 to run.![]()
That's why I ended up not going 1 tons. Why pay all that money for a stockfront end, when I can spend less on moly's and it will be just as strong......
That is until you break the front or rear pinion...
That is the achilles heel of LC diffs. While I agree that toyota diffs are strong, 42's are going to be stressing that rear 7.8" (actual measurement of ring gear on your rear third). Again, the ring and pinion are your weak point on both front and rear axles.
I have seen, watched and experienced toyota diffs take a tremendous beating, but a built one ton axle they are not.
30 spline vs. 35 spline is a big difference. This has been beat to death on PBB, one tons are more better. Toyota's can be built initially cheaper, but there is a limit and only so far you can take them, whereas 60's have a ton more potential and strength.
Sorry,
I do agree that 30 spline 60's aren't much to brag about, they were designed to carry weight not deal with HP, lockers and big tires. It seems that toyota 30 splines axles are stronger than Dana 30 spline axles, plus they make a different sound when they break.
I'll shut up now.
Jack
I really like Fruit of the Loom, BVD's always seem to bind in the wrong places. Plus I heard guys who wear BVD's are a little light in the loafers. But that's just rumor.
Drive what you like, I'll see you on the trail.![]()
HAHAHA....that's some funny S**t and too true. Me, I'm a Jockey man ;p.
Fruit of the Loom al the way baby! Those other brands are for poofsters.
I mean whats the point? You might as well go commando as wear boxers.Don't even get me started on boxers vs tighty whities.![]()
