Another 06 LX470
SF Bay Area
We just picked up another 2006 LX470 with 173k miles. It was a one owner car, no accidents, almost everything works with the exception of driver side mirror (up/down) and telescoping wheel (in/out). It also came with the extensive service logs (Carfax). When it stops raining I will go over everything once more and complete the services that I think it needs. One thing that I didn't like is some type of residue (see pics). It looks like radiator hose blew and spilled coolant all over the radiator. I hope the engine did not overheat. Is there a way to check that in the Mainstream? It also looks like heater Ts were replaced but they did not use factory clamps. Going to replace them too just in case. What do you guys think?
Ps. I will keep this thread as a log for all the maintenance and repairs.
there's nothing to check in tchstream, other than temp.
radiator looks bad, clamps, hoses, etc. Buying toyota clamps and the hose(s) is just easier than worm clamps.
There's a whole radiator thread of you have a week to kill.
Indication of overheating, in order of severity:
  1. Swollen coolant hoses.
  2. Browning of hoses.
  3. Leaky head gasket.
  4. Coolant in oil
  5. Discoloration of block.
  6. Melted plastic.
  7. Scored cylinders.
  4. Coolant in oil
  6. Melted plastic.
Can you tell form the photos if some of these sympthoms apply? Any idea that that white residue on the cover might be? So far I didn't see any coolant in the oil.
Only hose I see, is aftermarket replacement upper rad hose. So I've to little to go on.
"White" could be acid, salt or aftermarket coolant or combination of. Combined with, heat and dry plastic.
When radiator level low, even a little. Air pockets accumulates in the top of it and in heater tees. The plastic, then, prematurely dries out. As your plastic is. So, you for sure have signs, of running engine low on coolant long term. How low for how long, I can't says. Other than to say for many many heating & cooling cycles, over a period of years. If a few inches low, where it was still above top of radiator fins. It just ran hot. If much lower, where below tops of fins. It may have overheated.
Note: Water temp gauge, will read below normal op temp. Normal is center (3 o'clock) line or slightly above, when coolant level low. Since, water temp sensors, ends up in air pocket, rather than liquid.
The way to check coolant level and get air out.
After bring engine up to operating temp and above 2,500 RPM for 5 minutes (HWY drive best). Park on level ground or better yet. With front of vehicle higher than rear. In either event, cross level also. Check under radiator cap before sun up, after 5 to 8 hour cool down. Top coolant with Toyota SSL (Pink), to very top. Top resevoir to high line. If need to add coolant today, check again next day. Repeat until no more coolant can be added.
Watch fuel trims (FT) and engine coolant temp (ECT), while driving. There are many OBD device on the market. That wireless connect to your smartphone. I use OBDIImx for iphone, to get most date points (PID). I can get FT, ECT, AT temps, AHC Mpa, CAT temps and a ton of other PIDs, my BlueDriver OBD device can't. But BlueDriver seems more accurate on fuel trims. These OBDII devices read DTC (codes) and also log in the background, entire time they on. A very worthwhile investment, even if you don't wrench
Study for signs of over heating:
Get pictures of all rubber hoses, vacuum & water. Study for swelling, discoloration, harness and cracking.
Examine, ever inch of head gasket. Use a flashlight from below looking up along block to head gasket. For the head gaskets inner area, in valley under VVTi intake manifold. You'll need a borescope to study head gasket.
Watch for smoke with a sweet smell, especially on cold start-up. (not to be confused with conidiation/vapor)
If you see, signs of head gasket leak or just want to dig deeper:
When replacing spark plugs. Study plugs, for steam cleaning.
Use borescope to study inside cylinders on piston tops & head chamber for steam cleaning.
Pressurize coolant system to ~15PSI, while engine cool. Use a borescope to study head gasket from within cylinders, for drips of coolant.
Do a compression test.
Look at my Master Thread which you'll find a link to in signature line. You mat find some help threads within it. First study the alerts at top of page.
Since you the VVTi engine and I see sign this vehicle from humid, hot and likely salt air climate. Your S.A.I. filter has likely already failed. So for sure study my S.A.I. filter mod, under alerts. I use a borescope, with 6mm direction camera lens, to inspect this filter. One may be able to see, with the more common,8mm directional (IDK).
I am going to take it to my friend mechanic tomorrow to dig deeper. Question, if it ran hot or overheated do you think it might've cause some type of engine damage that may surface sometime in the future? I'll definitely send out a sample to Blackstone for analysis.
Overheating, can blow head gasket and or warped heads. That why I've offered, specific inspection and test. If heads good, damage from running hot, is just hard on rubber & plastic.
If no obvious signs of engine damage in the present moment (white smoke, misfires / CEL, having to add coolant every few days/weeks) and the UOA comes back clean I wouldn't worry about it.
The way I see it is with how old these trucks are and all the possible coolant issues / leaks (tees, radiator, water pump, hoses, wrong clamps, wrong / mixed coolant, etc) there's a decent chance many of these have either run hot and/or low on coolant or otherwise would fail cooling system inspection at some point in their lives.
My truck had a service record from the original owner where it was taken into the shop to "check overheating". Pressure test was done and radiator was found to be leaking and had to be replaced. I still bought it. Later the water pump leaked and I found my reservoir empty and radiator low (not empty). That was years and tens of thousands of miles ago and my truck still runs fine and multiple UOAs show no coolant. If my HG pops I'll deal with it at that point.
I consulted with my mechanic and he said that the white residue on the radiator looks like an acid from some chemical that was used to clean it and not removed/washed off.
Had some time to inspect everything and knock out some maintenance items off the list. Head gasket is clean no leaks, spark plugs are nice and clean, coolant level is holding up fine, oil is clear. I think I might've dodge the bullet on this one, phew! On the other hand parts and fluids that we replaced were all dirty and probably very old.
1- PCV valve was all gummy
2- Rear diff pretty dark
3- transfer case, black
4- Front diff, also black
5- Suspension fluid, black
Going to tackle transmission service next week. Not expecting any fresh fluid there either.
Transmission fluid exchange done on January 31st 2026. Fluid was pretty dark black to be exact. Pumped 13 quarts of Asin WS fluid trough, cleaned pan and magnets, cleaned strainer, replaced strainer gasket, replaced pan gasket (both Toyota OEM). Set level using Techstream.
February 14th. Discovered some rodent damage to one of the injector wires. Repaired with soldering wire connectors.
February 7th, truck shut down again with code P0113 and P0102. Traced it to bad aftermarket MAF sensor. February 14th replaced MAF sensor with OEM Toyota/Hitachi sensor.
February 22nd: installed Hikari LED bulbs in low and high beams. Had to order longer seal caps to accommodate longer bulbs. went with Lasfit which are a perfect fit, just need to drill a hole for wires. Decided not cut OEM covers off, instead ziplocked them and set them aside incase I ever need to revert to OEM. Light is pretty bright especially high beams.
On the same day replaced old discolored buttons on the steering wheel. Amazon sent me wrong style which has front cam button on it too. Instead of waiting another two weeks for a correct style I went ahead and installed those. Everything works perfectly as it should, quality is really good (touch, clicks, light etc...).
February 28th: Installed Grom Audio bluetooth unit. Works really good, now I can listen top my music from the phone. If someone is going to do this, you do not need to unplug all connectors. There is only that needs to be unplugged applicable to this model.
