anothe OME spring question
CHARLESTON WV
I am doing some work to the cruiser and will be installing my new OME springs in the next few weeks and from the Slee site:
IMPORTANT. In the US, with left hand drive vehicles, if the springs are labeled DS and PS, we install the DS (Driver Side) springs on the PS (Passenger Side) and visa versa. The springs are labeled for the right hand drive vehicles. If you can not locate the labels, or you have used springs, make sure you mark the springs that you remove from your vehicle and match long with the long and the short with the short springs.
Lately some springs are labeled A and B. A is for Australian driver side, so in the US this should go on the passenger side and B should go on the driver side.
my question is, if the spring is on the right in austrailia [drivers side] shouldn't that spring go on our left [drivers side] due to weight of driver matching that spring?
just asking before I do this of course, right now doing rear brake calipers/rotors/pads and soft lines plus one hard line that has some corrosion, then moving on to the springs and shocks
thanks
doug
The different spring heights have nothing to do with which side of the road you drive on. The springs are different heights because the perch on the longer side of the axle is lower than on the shorter side. No matter where you are, the taller spring always goes on the longer side of the axle.
From the Slee site "7. IMPORTANT. In the US, with left hand drive vehicles, if the springs are labeled DS and PS, we install the DS (Driver Side) springs on the PS (Passenger Side) and visa versa. The springs are labeled for the right hand drive vehicles. If you can not locate the labels, or you have used springs, make sure you mark the springs that you remove from your vehicle and match long with the long and the short with the short springs.
Lately some springs are labeled A and B. A is for Australian driver side, so in the US this should go on the passenger side and B should go on the driver side."
I just put on a pair of OMEs labeled A and B, and followed the above directions. Looks good to me!
