AN / JIS Fitting Sources?
jaymar
SoCal
Have an aftermarket radiator here, no clue what fittings it's using for tranny cooler lines. Could be AN, could be JIS, could be something else. Two questions...
1) Are there any walk-in brick-and-mortar suppliers I might try for a quick parking lot test-fit? (Local Lowe's and AutoZone have never heard of AN fittings.) That could tell me if AN, rule it out if not.
2) Where would you source JIS fittings online (in case that's what I have here)?
id look for a napa or similar store that makes hydraulic hoses and see what they have
Thanks! Closed now, will give 'em a try if Pep Boys is a wash. :)
I wouldn't even both with pepboys although they may have some an fittings, id just try to find a hose shop. they'll have every fitting that you should need or at least be able to get them, im fortunate enough that I have a napa that happens to also make hoses
Right UR; Pep Boys a wash; they only have one size: -6. Goes on a turn or so, then jams up.
Do all napas make hoses? There’s one maybe 20 miles off.
M14 x 1.0
The napa by me makes hoses and custom battery cables
Will try that tomorrow at napa, just to make sure mine's the same as yours. What do the other ends of the tranny lines look like--same fittings there? Thanks!
Planning to go with Fragola Push-Loks for radiator end.
Jaymar are you making new lines for a transmission cooler? I ask because I don’t know if I should buy used Cooler + hoses OEM or make my own and buy aftermarket cooler?
No I subscribe to the Toyota school of thought on this one--marry it to the radiator. Installing new radiator with integral cooler.
Try luky’s Hardware in Burbank lots of stuff there.
Never knew about them. You know about Koontz by San Vicente & Santa Monica? Awesome hardware store.
Everybody is a wipe out. No one does metric connections. Can’t even find a metric thread gauge at a brick and mortar. Amazon it is…
To know for sure what your dealing with measure the angle on the male fitting mating surface. If it's 37degrees it's AN/JIC, if it's 45 degrees it's SAE. Earl' fittings has just about every type, and style of AN/JIC fitting you can think of.
