Ammeter; installing
EVERGREEN, CO, USA
Anyone installed a new ammeter from SOR?
'79 FJ-40; mostly stock
Yup.
I love that!
Any problems? Can u tell if its OEM or aftermarket stuff?
yes......take cluster out and go from there. make sure its the meter, might be the fuses or the links, forget when they changed the way the amp meter works, it was 79 or 81 though
rgentry said:
Unhook the battery before you start. Otherwise, you might
be buying two ammeters.
OR ANOTHER WIRING HARNESS!!!! :eek: :eek:
speaking of ammeters, i havent hooked mine back up yet, mainly because a tech at painless said they dont recommend using them due to fire hazard/ preference of voltmeter. anyone else feel this is a valid concern or should I just hook the ammeter back up?
Well, I have to say that my FJ45's harness once blew up and burned for some reason. That and the 71's ammeter are wired in series to the rest of the cab. Later trucks have the ammeter wired in parallel. Perhaps some of the electrical wizards can say for sure, but I think that have something to do with the risk and reducing it. That being said, I think that the ammeter tells you a lot a voltmeter will never tell you in a million years, it is far more sensative, and any wiring arrangement can cause a fire if the wires are not protected and the insulation wears through at the wrong spot.
Both my rigs are wired now the way they were originally. I'll bet the Painful folks have no ammeter experience.
I like your new avatar, Thorvald!
I'd say u can hook it up; if u don't have a high out put alternator. Most of our FJ40's have a 40-50 amp alternator, and Toyota decided to wire the alternator inseries with a shunt on the ammeter (inside the cab) and then back to the battery; just the way all cars were made for the last 100 years. Then, in the interest of safety, they used a shunt under the hood (engine compartment, wiring loom), the shunt is called a fuse link. This allows low voltage and current leads to be fed to the meter without worrying about high current leads being fed thru the firewall; i.e., potential fire starter. I may do a digital ammeter like here:
http://homepage.mac.com/dfmorse/RigProj/page1.html
I'm not really happy with the way OEM wiring is done; if the fuse link (Part # 90982-08071) is blown, for what ever reason, the current/voltage surge can destroy the meter movement.
A high current wire has to go into the cab no matter what so there is always some danger. That is why these wires must have a fusible link. With the older cruiser amp meter, the difference is that there are two high current wires entering the cab; one from the battery and one from the alternator. After about '78, Toyota moved the shunt outside the cab, using the fusible link as a shunt for the meter. Both of the meter wires are fused, to protect the meter in case the link burns out.
One trick for using the OEM meter with high output alternators is to double the internal meter shunts and run new, larger wires. Two shunts doubles the capacity so that the original 30-0-30 meter will now indicate 60-0-60.
QSL, 73s
Tnx for that update PinHead. According to my schematic, Toy uses two 5 amp fuses for the meter, seems kind of high, doesn't it? I haven't really shot the circuit yet, but its on my do list. Right now I'm useing my dremel to cut holes in my left front fender to do a rust prevent job; much fun!!
73's
k0dar
Now off to Slee's for a big party
My recollection is that the fuses are 0.5 amps; 5 amps wouldn't do much good. If you are talking about the pdf schematic for '78 FJ40s that is on tech links, that shematic has a number of errors, mostly in labeling and color code.
Ur right! I'll mark up my 1980 schematic to show 0.5 amp. By the way, have u measured the stock fuse link for resistance value? Just wondering if it conforms to the 50mv standard.
dfm
I just looked at my 1980 schematic and it does list the fuses as 5A. It is hard to believe that is correct. I don't know the stock link resistance. It is probably easier to calculate it by measuring the meter resistance and the full scale deflection current of the meter.
Shunt resistance / meter resistance = measured full scale current / indicated full scale current (30A)
