Am I over reacting?
BGMachine
Working on cars I can't afford
SE Michigan
Hey all,
I have a diagnosis question. So I was doing some work on the 80 today (cleaning the egr valve and modulator) and I turned it on to test it. The exhaust was white, wet, and had a bit of a sweetish smell to it. but after the engine warmed up, the smoke was gone, no more wetness, or sweet odor. Is the head gasket going or am I paranoid? I also did a coolant flush recently and replaced the thermostat to a 170 degree unit because I had noticed the truck running around 204 at 65mph in 80F weather (scan gauge reading) along with a temp sensor fault code (also replaced the sensor). Did I mistake the warmer temperatures for a thermostat issue when it's something else? Are there any ways I can test for head gasket failure besides checking the oil cap? (oil looks fine) Also, the truck has 237,000 miles on it and as far as I know, it has the OE gasket. Thanks for the advise all.
My 97 does the exact same thing you have just described if below 65*F ambient temperature. I was really worried at first. However, I have been keeping a close eye on HOT & COLD coolant reservoir levels and those marks have not changed one bit. Also after overhauling my cooling system the engine temps have been considerably cooler (never over 190).
If you think you might be loosing coolant.
- Check for external leaks
- Use the pH tester (bubble tester) on the radiator to screen for exhaust gas in coolant
- Send motor oil sample to BlackStone to examine for Potassium / Phos in the oil.
Have you upgraded the silicone on the fan clutch?
I had similar problems a couple of years ago. Turned out to be a plugged up core. So I replaced it with a Koyo 1918A from Amazon.
Runs great now. John
Ok, today was in the mid 60s so that could be it. I'll just have to watch coolant levels I guess.
I haven't touched the fan clutch. I'll check that out as well.
I think I'm gonna do a compression test to see what it's making just to be safe.
Sounds a lot like my problem. Was very much like described in this video.
I love the block design and ruggedness but start to wonder is the iron is cause the system to deteriorate. Thinking about giving this a shot when I am finished replacing my cracked cylinder head.
I think it is all related to the egr rusting out along with those nasty vacuum lines that are metal that connect the rest of the 3 mil lines to the vacuum systems. Also the charcoal and PCV valve were completely clogged.
ARGh.!
If you're really worried just buy a block tester kit from NAPA, that's what I did. It tests your cooling system for signs of combustion gasses leaking into the system. It was $45
