aluminum drawer system
Very cool, ive been toying with the idea of making draws from Ally or the other stuff posted about with the space for sliding nuts ect.
would be able to post a better pic or the PDF of your design if you wouldnt mind
Cheers
Tim
If you would like a copy of the drawing in PDF as well as the other notes and specs that i have so far please send me an email address and i will be more than happier to send it to you.
-Mike
-Mike
Mike,
Send me a copy too if you don't mind: alia176 at yahoo
On another note, seeing as how your slides are so expensive and already bought, this point is moot. However, wasn't there any way to buy some metal wheels/races and make your own track? I've seen people use simple bearings for this application too with built in stops and such. Perhaps you investigated this route already but decided against it?
Keep up the good work.
i had thought about making my own slides, which actually would not be all that difficult, but decided to go with some that were already rated for heavy weights, the last thing i want is to have a spindle for a bearing break from fatigue and have the drawer be stuck. I eventually will end up with a slide on top for a fridge, that i will engineer myself more than likely. Thanks for the comments.
UPDATE
well, i had a few days to work on the drawer system, but didn't get too far as other obligations kept coming up. But here are some close up pics of the joints that were asked for.
UPDATE cont.
Also i took some pics with the frame test fitted into the Cruiser, perfect fit, snug and everything lines up for mounting. I'm using the 8 holes in the floor. The only problem i've had with that were sourcing the M10 X 1.25 in button head, but i may have found a source in England. Also i went and picked up the 1/8 aluminum sheet (4x8) that ran another $163.00. After making the template for the top out of cardboard, we cut the sheet using a scroll saw and metal blades, quick work. I had hoped that i would be able to get it into the rear hatch but not gonna happen, too big. so i have decided on the sides to be hinged the full length of the box, and some additional bolt on braces under the "wings" which will be put in after the main box is set in place. Up next will be to TIG the slide mounting points in (didn't) have time this trip, skin the top, attach the piano hinge for sides and rear compartment, and have the drawers fabbed. Since i don't have a brake yet i'm outsourcing the drawers themselves.
That is a sick drawer system. I can't wait to see the finished product!
i've been extremely busy as of late, but did receive the mounting bolts i ordered from England. Ouch expensive. After talking to the powdercoater they think they can match the antique sage pearl so that will be the color, topped with matching carpet the drawers themselves will be rhino'd. After finding out the large sheet won't fit in the rear requiring me to hinge both sides, i've mocked up the supports for the wings. Also i am going to add an inverter as well as an air hose bib.
Also besides the drawer system i've started the prelim drawings for a baffled water tank to replace the second row seats for long trips. It will be stainless.
I had hoped to have the majority of the drawer system done by SnT but there have been other things that take precedence. It may still happen but have to wait and see.
ahem, updates?
Uncle Sam has had me busy lately, so no time to work on any of them. grrr, hopefully before christmas. Sorry guys
Wow! verry clean. Nice work. But are you worried about the streangth of the frame neer the drawer front? It seems that 3/4 square tubing would not suport that much waight on that 2'+ span. I would hate for it to bend on you.
Looks great so far! Cant wait to see the finished product.
excellent workmanship!
I can't wait to see the finished product.
:cool:
Should be plenty strong , I have had no problems with my set up and its a 28" span and a 3/4" x 1/8" angle supporting it. The skin @ 1/8" welded to the the angle makes a pretty ridged structure.
( Im well under 200# ) JFR
ken
