Alternator with 2 pulleys Question???????
Clearwater, FL
Hi,
I am posting for a friend. He called me and said his 81 FJ40 has a terrible noise that is coming fom the front after he starts her and gets worse after he revs her up. I went to see what is going on. Just to mention, he is not mechanicaly inclined at all.
What I found was quite interesting. Cruiser has A/C compressor (hoses not hooked up yet) mounted on top of alternator using some kind of home made bracket. Alternator has two pulleys and I don't its a Toyota one, because OEM usualy has one pulley, right? Alternator and A/C compressor were connected with a very small belt, not toyota one.
After he started her up, the noise and pretty loud banging noise was coming either from A/C compressor or Alternator. I was able to remove the belt between them to determine where is the problem.
After I removed the belt and he started her again, it was obvious, the alternator was making horrible noise.
Do you guys know which GM alternators with double pulleys will work?
Thanks,
Alex
If the wiring on the back of the alternator looks pretty simple, there is a chance that it is an ordinary alt with a double pulley added. Shouldn't be a big problem to buzz the nut off and transfer the pulley to another alternator.
The real problem is the booty fab a/c running off the alternator. Way too much drag to put on an alternator. Better answer is to round up a stock alternator for now and tell your friend to hold off on the A/C until it can be dealt with properly: belt directly to harmonic balancer.
