Alternator/wiring issues
Bainbridge Island, Washington
This may be a tough one. What I am looking for is some direction in diagnosing and fixing an electrical problem. 1978 FJ40, had a drivetrain resto about 10 months ago.
When driving at night, my headlights surge dim to bright over and over again. It stays more steady when the throttle increases.
The volts are fluctuating just like the lights are, in fact everything electrical fluctuates. This problem is all of the time, but worse once the vehicle is warmed up.
Question, where to I start. could I have some wires on the alternator mixed up, is the alternator dieing, is it a battery problem? I just don't know where to attack this annoying problem.
Also, the battery stays charged and it starts.
Thanks for any advice in advance.:)
I would say the problem is probably your regulator.... let me dig up the wiring diagram and it should be able to help you... just a sec
dan
I sent you an email... I would sugest checking the grounds first of all... all of them... then go for the regulator
good luck
dan
What does the amp meter indicate when the voltage drops? If there is no significant amp drain, then it is probably the regulator or regulator wiring (assuming that you have a stock alternator). If there is a significant charge or discharge current (like 25-30 amps), it may be either an intermittent short or bad battery.
the amp meter has about a 7 to 10 amp difference when this happens. That is what the meter on the dash says. I have not gotten out any tools and checks the resistance of anything yet.
and yes Pinhead, I do have a stock, (or stock looking) alt on it. It isn't a Toyota one but it says reman on it. I couldn't tell you how old it is though.
Cornbread;
The following manuals will help:
Pub. No 98126, Page 9-2
Pub. No. 36104E, Page 9-2
Assuming that u have an external regulator [not a regulator built into the alternator], u can clean and adjust same as seen on page 9-37; manual 98126.
Be sure to clean all connectors, Battery, leads from alternator, etc. Check all ground leads and retighten same.
How old is the battery?
The DUI should not affect charging, its a self contained ignition that wants 12-15 volts DC.
Ok, Thanks for all of your patience. Electricity is not friend usually. I just went out there and got some more infor for you guys. My voltmeter in the instrument cluster goes from -30 - 0 - +30. When I turn my key to ACC or IGN, gauge says -3 or -4. When I start it up gauge momentarily drops to -20 or so then jumps back up to -4. when lights go on -7 or -8. Lights plus Heater, -10 or so. Lights plus heater plus wipers -15. I just checked the main ground and it is clean and good. I checked the volts on my battery before start up, and 12.56 or so is what I got. Then checked the volts on the battery while running at 15-1800 rpms, and my handheld voltmeter and it was still at 12.56 volts. Then my handheld voltmeter went tits up and kept maxing out even when I wasn't touching anything ? Now, my voltage regulator on the Pass firewall, is the ammeter type with 3 prongs.
I do have one question, the 3 prongs on the back of the alternator have 2 wires connected to them, both of which go straight to the fender and ground. Is the placement on the prongs critical (I'm assuming they are). can that be the problem?
Actually 2 questions. After messing with thos wires, now it won't run at normal rpm range, I have to keep the Rpms up to keep it running and the blinkers are constantly lit when I turn the lights on.
I am truly sorry for the long post, I just really need to find out what the hell is going on with the electricals.
Josh
That's not a volt meter; it is an amp meter. When it reads -, your battery is discharging and when it reads + the battery is charging. Normal state is straight up at 0, indicating that the alternator is working and the battery is fully charged.
Since yours reads -, the alternator isn't putting out. Does the voltage ever get above the 12.5 that it reads when the engine is not running?
Right now, you can conclude that your charging system isn't working: alternator, regulator or wiring. First thing to do is check the "engine" fuse. This fuse also runs the idle fuel solenoid, so this would explain why your engine won't idle.
Only one wire (white w/ black stripe) from the alternator is a ground wire and it goes all the way back to the regulator. The other wire is the "field" wire from the regulator that regulates the alternator output (white w/ green stripe).
If your running lights or turn signals come on when the headlights are on, you have a bad ground in your lamp housing). The running lights always come on when the headlights are on.
Study this:
http://www.yankeetoys.org/documents/wiring_diagram_78_fj40.pdf
OK a little update. This electrical stuff is not fun. I can rebuild the engine, tranny, transfer case, axles and everything else, but I cant wire an alternator right.
1. The wires on the back of the ammeter were switched up. This would explain all of the negative values mentioned earlier.
2. The ground wire (E) on the alternator was in the wrong spot and nearly melted down. In fact, I had to replace about 18" of the wire.
3. replaced the engine fuse as it had blown. This was tough because the previous owner had broken a few prongs and sodered (sp) half of the fuses in. I knew this would come up someday.
Current status the Ammeter starts off when running about -10. Then after warm up it sits about -2 or so. It never changes from that spot. When accessories are turned on, the ammeter fluctuates, put promply returns to -2. I am not sure if this is acceptable, but the surging of the lights problem is extinct. The blinkers work too. I don't know how but they do. I have only driven it for about 20 mins so I don't know if it is having a charging problem or not.
Moral of the story, know how to read a wiring diagram.
Thanks for everyone's help. Please let me know if you all think I should test the voltage reg. or the battery or the alternator. I have to go buy a new multimeter today.
Josh:beer:
Battery = 12.6 volts sitting about 14.7 or so running
Alternator B terminal to battery neg = 15.5 volts running
Alt F to E with Ignition on not running = 13 volts
Voltage Regulator = F to IG- 0.5 ohms
key off IG to E - 90 ohms
F to E - 90 ohms
All volts are in DC.
I was going to replace the voltage regulator as it is like 20 bucks at NAPA. Do you all think the Alternator is fried. Again everyone has been a big help. I have been driving it for about 3 days now and nothing has changed (i.e. it still starts fine).
You alternator is working.
I'm not sure that your amp meter is wired properly as it should read + (charging) immediately after you start it. What does it read with the engine off and all lights and accessories on? It should read - (discharge). Alternator B+ wire (white with blue stripe) connects to the - side of the meter along with the wire to the ignition switch. The + side of the meter goes to the battery (white wire).
Try this page out you may have to look around but it has a lot of info about alternators, voltage regulators, and generators.
http://www.madelectrical.com/
I think it’s your voltage reg. your alternator is putting out some volts or it would not have run this long.
My 2 cent
Attn all:
Thank you for your help. The winner is Pin Head. My ammeter wires were hooked up correctly the first time. White to POS and white/blue to NEG. That and the fact that my E wire was not hooked up correctly to the alternator. Which means I had no ground off of the alt.
1. I will be reading the website Jakes40 recommended.
2. It is always good to invest in a multi meter
3. It is even better to know how to use one.
4. Even more important is knowing how to read a wiring diagram.
Nothing was damaged during this fiasco exept my pride.
Thanks Mud and all who have helped.
Josh
Attn all:
Josh
The ground wire at the alternator is redundant and it should work without the wire. The wire is there to provide a good ground connection to the voltage regulator in cases when the other engine and chassis grounds are bad. The fact that you need this wire suggests that the engine or VR may have ground issues.
There is some useful information on the madelectric site, but you have to take some of it with a grain of salt. Some of their claims have a rational basis, but some claims are solutions to things that aren't a real problem, like remote voltage sensing, voltage drop at headlights and amp meters being worthless old school wiring.
Just a side note, the ground from the alternator (E) wasn't on the E post it was on the IG post of the alternator and it was melted pretty bad. At least the first 14 inches of it was?
It is all smoke and mirrors to me most of the time.
