Alternator wiring correct?
marketShark
Spider 2 Y Banana
Austin Texas
I changed from the older style 3 outlet alternator connector plug (with only 2 of the wires connected) to the newer style? that came with the donor engine.
I pulled the wires out of the connector and was going to hook them up directly. Looking at the wiring diagrams can't tell what goes where on the alternator.
Question is- do I have it correct? I figured I had a 50-50 shot
Wire colors are the white (green stripe) and the white (black stripe).
Little things like what alternator and what year alternator would help. It isn't obvious that it is an externally regulated alternator. If it is externally regulated, then the white wire with green stripe goes to the F terminal. White/black stripe is a redundant ground wire and it goes to the alternator case. If it is an internally regulated alternator, then you need to attach the white/green wire at the voltage regulator to the black/yellow (Igition) wire and then hook the other end to the Ign terminal of the alternator.
Hey mud, how can one tell if the alternator is internally or externally regulated?
Based on what @Pin_Head says above I’m thinking mine is internally regulated.
Year of the alternator is unknown but the vehicle is a 77’.
My white/green wire was pretty trashed so I replaced it back to the “T” with a donor from another harness, same with white/blue.
At the “T” there is a handful of white/black wires butt connected into one wire and was previously ran to the “E” post. Can anyone share what this is supposed to look like?
I found a donor connector that fits the back of the alternator but I’m just trying to confirm how this is supposed to look.
Also, should I run a heavy gauge wire from the alt positive post directly to the batter?
