Alternator Wire upgrade
Chattanooga, Tn
PO installed "big 3" upgrade. He removed factory wire and taped it up. This wire is still hot of course. I'm wanting to hook it back up to the alternator. From what i've seen on big3 installs is some people keep the OEM wire hooked up, and some remove it. Is it okay to leave connected? I can't see any harm in it, just wanted to be sure. Thanks
Searched big 3 and found nothing. What is that?
I've upgrade my alternator wiring with the "big 3". I have no idea what you're talking about though. Are you saying that you have a hot wire coming off of the positive battery terminal that's just taped up?
Turns out i have done this mod as well and i also do not understand the issue here.
Yes. The factory wire that used to run from the alternator is just taped up hanging there. The new wire is connected. The factory wire is still hooked up at the battery side FL.
If i understand what your saying i would either connect both or remove from battery. I would not leave it hanging just taped up.
After looking at picture i would also probably run both. Looks easier.
If you leave the factory wire connected at both ends, then you would be effectively bypassing the MAIN fusible link, like this:
I would leave it disconnected at the alternator, and also fuse the new wire at the battery.
I'm leaning towards pulling the upgraded feed to the alternator and just leaving that stock protected by the FL. I don't see a need to have the factory feed replaced. Just cost more to install a new fuse.
