alternator voltage output
Billings, MT
does anyone know the voltage production that a stock GM alternator for a SBC will put out. I am thinking of getting an aftermarket ignition system which has a maximum operating voltage of 18 volts and I don't want to have a new ignition get fried. When testing for voltage would I place my voltmeter pos lead on the wire running from the alt to battery and the gound wire to the frame? Thanks for any insight
Brian
It'll normally put out 13.5-14.5. You'll have no problem. Even if they fail and put out full unregulated voltage it is only about 18 volts.
Just connect your + meter lead to the + battery post and your - meter lead to the - battery post. It's the same as what you mentioned, just easier.
Not to poke too many holes in your response, but an alternator can produce very high voltages depending on how much field current is allowed to flow in the alternator. Here is an example where they are using a conventional alternator to produce 110v by controling the field current apart from the standard regulator. http://www.motherearthnews.com/DIY/1985_January_February/Make_Your_Own_Emergency_Power_Plant
I'm not sure how high a voltage could be produced from a defective regulator. It's in part controled by the breakdown voltage of the diodes, and other parts contained within the regulator itself. But I'd bet Dollars to Donuts that you could easily surpass 18v with a faulty regulator, especially a mechanical regulator. But this is for a malfunctioning regulator, not a functioning one.
Again, not intended to flame, just add some clarity. Hopefully.
Jeff
I've seen way over 18 when messing with alternators. high side of 20 (25+?). Been a while, don't remember exactly. But higher is definitely possible.
But unless you have an (unusual) flaw in your alternator, higher than normal voltage is not something you ned to be concerned with.
13.8-14.5v is the standard nominal range for 12v automitive systems.
Mark...
The voltage you get depends on the load, the RPM and the field current. I have gotten over 150 V DC out of a large case Ford alternator with full field and no load. I easily get 100 V to run an angle grinder, but 17-18 V is about the max with the alternator hooked up to the battery, because the battery can sink a lot of current. As long as the alternator is hooked up to a battery, I doubt that you will have a problem.
