Alternator connector removal
Somewhere
Hello,
I am removing the alternator from 80 (1997) and have problem with the connector. Any idea how this complicated thing works ? Need to disconnect it.
Jorge
With your right hand push down on the connector tab (top left on the connector in the photo) with your thumb while your index finger is gripping the opposite side of the connector then pull straight backwards or out.
It's not possible I even took grips and broke the connector a little bit . Now it's out , what about the pin on the side of the alternator ? Shall I use brute force or not.
this can be very big PITA much more if it's toasted from engine bay heat .. you can order a new replacement ( connector ) and if you destroy yours in the process will have replacement handy ..
I pushed in the tab facing me with a dull screwdriver until I heard the clip pop (not broken just popped from the tab). Then I used two paint can openers with curled ends to walk the connector off the alternator using the tabs on top and bottom of the connector. I did rock the connector first some to loosen up the built up dirt that was in there.
