Mine is starting to do this, i tried it this morning. Not as bad but I don't want it to go out on me. It looks like the 100 amp one is the one i need?
The 'good' thing about alternator bearings (if there is a good thing) is that they tend to give a 'warning' sign (whining) before actually failing. In other words, its unusual for them to just hard fail (suddenly).
Most of the time...if you have the tell-tale whine...you will have a month or more before it gets noticeably worse. If you replace it soon enough, then you might be able to rebuild the original for the same amount (or less) than the core charge and keep it as a spare. You can determine that by opening it up. Mine was not salvageable, it had been too hot....too many times.
Yes, the 100 amp version should be correct for your vehicle.
