Alternator bearings?
Colorado Springs
Anyone ever replaced just the bearings in the alternator? Mine appears to be whining and I'm wondering if that will provide a fix?
Replace the bearings and see. Use Japanese bearings (NSK, SKF, NACHI) and should be about $10 or less a piece. Disconnect the battery before removing the alternator. Also, install new OEM brush kit $22 at the dealer. The alternator should be good for another 200K miles
I wouldn't even consider going that deep into an alternator without also replacing the brush assembly and voltage regulator.
You might want to pick up a new 'connector' as well. Most are brittle and will break when you disconnect it to remove the alternator.
Soooooo at this point am I smarter to just look at a reman? Or fine to rebuild?
I paid a shop $75 to rebuild my Motorcraft alternator. He gave me a warranty and said he went through it. It worked great. There may be someone in your area that does this type of work.
Is it OEM? If not pass it. Try Camelbacktoyotaparts.com. I saw they have good prices for alternators.
The bearings are number 3
Brush kit as stated above is 6
I will not buy a reman alternator for a toyota as they may last 100K or less. Also, reman alternators have cheap Chinese brush kit and rectifiers and those are poor in quality. The voltage it provides at idle with headlights, AC on can drop to 13 V or less while OEM toyota parts will supply 13.5V or above.
The number 7 is the rectifier. It will go bad if you draw more current than the alternator can produce or short circuit it. Otherwise, it should be good even after 17 years.
You can replace the AC pulley bearing: it is 55mm 22mm and 30 mm OD Thickness and ID respectively. There are threads on how to replace it. You don't have to evacuate gas to do it. Make sure to buy a branded bearing. All Toyota's have the same bearing or at least my 92 corolla, 97 4runner and 00 cruiser.
Thread on 4runner forum for AC compressor: Toyota Denso AC Compressor bearing and Idler bearing replacement - Toyota 4Runner Forum - Largest 4Runner Forum
I'm doing OEM the entire way and it was that price. I'll check out the compressor bearings. The truck has 203k on it, I'm assuming this is normal mileage for these two components working their tails off without a hitch.
The only bearing you'll want to consider 'serviceable' on the compressor is the Clutch Bearing.
The compressor sounds like it's groaning almost, I don't know what parts go bad on those
I just had my alternator, and serpentine belt replaced and had an oil change. $460 out the door. My LX also has almost identical mileage to yours. Last summer the previous owner had the alternator rebuilt and 12 months later this is where I ended up.
First thing to do would be to determine IF your alternator bearings are going bad (probably are at that mileage). Generally, they develop a 'whine' prior to failing....BUT there are other components (power steering, etc) that will do that too. One way to help isolate it is to introduce a 'load' to the electrical circuit and listen for an increase or change in pitch of any noise/whine.
When my alternator bearings began to fail...there was a distinct whine. Just to substantiate my suspicion...I started the engine, let it idle and turned on my headlights. Then switched them back and forth between high and low beams. Each time I switched them to high beam (increased the electrical load), I could hear the alternator whine louder. See video below.
After changing out the alternator, all was quiet again.
Replace the bearings and see. Use Japanese bearings (NSK, SKF, NACHI)...
SKF is Swedish, but still good bearings. Not that nationality or continent matters in this thread...
Mine is starting to do this, i tried it this morning. Not as bad but I don't want it to go out on me. It looks like the 100 amp one is the one i need?
