Alternator Bad
bad ignition switch, bad starter motor and by passed ballast resistor
Used the starter off the 85 and it is awesome:bounce:.anyone have any ideas on an easy way to remove the nut that holds it on the engine side:steer:?.....that one was a :bang:bitch.......about 1 1/2 hours worth :frown:am going to try rebuilding the one I took off and would like to put it back in after rebuilding......but hate trying to remove that far side nut again:eek: TIA
Lou
three things needed to be solved to correct this problem and the circuit back to specs............
ignition short; bad starter motor and a ballast resistor that had been bypassed by the PO; could not have solved it without y'alls input..:beer::cheers:
Lou
delco-remy starter on toyota F 1 1/2?
:wrench:Follow-up; this evening decided to get the crud off the starter I took off the 74 F 1 1/2 to begin rebuilding.....this was a surprise:hhmm: anyone seen a chevy starter on an F 1 1/2 series motor:confused:......it is about 30% larger than the ND I replaced it with and it was a bitch to get off:bang:..........the 85 nippodenso was a cakewalk to get on:hhmm: appreciate any opinions on this..........was thinking about rebuilding but this being a delco-remy changes things a bit:confused: TIA
Lou
Pin, thanks for the words of wisdom.... noticed that Delco Remy starter motors are a LOT cheaper than NippoDenso; must confess:o that when got the prices the thought crossed my mind about going the POs route again.........but heck,the one off the 85 works beautifully and soo much better than the DR....so might just wait for a used ND to rebuild and stash; thanks again:cheers:
Lou
