All TC options for H151F
Arizona
Hello. I'd like to have a list of all(modified, OEM, non-OEM) transfer case options for the H151F. Thanks.
What are you looking for, you know this forum has a search tab, and by you typing in what you are looking for, you might get some answers, and then you can GTS Google That s***, I have heard there are lot's of answers there :meh:
I did a bit of calling around to dealers of the H151f here in the states but no one seems to be able to answer some fairly basic questions regarding the trans and transfer.. The big picture here is I want lower gearing(crawling) and want to keep my H151f..
Assume you are installing this in an 80 series.
Your answer is to add a set of Marlin 3:1 low gears, and Terrain Tamer .85:1 OD in the HF2AV. Contact Georg @orangefj45 from Valley Hybrids as he can supply both, and install if you send him the T-Case. I run this setup in my 80 with 4.10s on 35s, and just completed a 3000 mile trip with average MPG of 21. Not a cheap option, but a very solid and versatile one.
Another option to consider is to install the part-time kit while you are in there; though I prefer AWD and kept the VC in mine.
It's installed in a project truck I built, probably 2k lb less than an 80. I like everything about my set up and want to add LOW gears to do a bit of mild crawling... 529's and 3:1 for the price "most likely" wont get me what I'm after for the 2k. 4:1 would be great..
What Steve said. :bounce::bounce2:
Georg can provide Terrain Tamer gear sets - crawler for low range and OD for high range for the 80s and 100s.
I suppose I can reach out to OZ where they're more familiar with running H151f's. I bought my shift boots from an outfit there. When I get answers I'll post them...
The answer will be the same, just different supplier, plus shipping from AUS if you choose an Aus supplier.
H2FA transfer is the same over here too, you guys actually have more after market options than we do.
Steve is on the money
We have installed quite a few of the OD Terrain Tamer gear as well as the 3.1:1 low range Sumo Gears in the HF2A cases and currently have both sets in stock.
Georg @ Valley Hybrids & Cruiser Brothers
Update: According to Marks4wd, HF1A from 91-96 70 series with 5 speed split gearbox will work. They sell a set of gears to achieve 3:3:1. With the added bonus of HF1A part time, an interesting option... however gears from Marks4wd 2,600$, ouch...
