Alignment Question
If you ever get pulling from this, and that's a big if, it probably won't manifest itself until the tires wear in more.
Just for fun, you could use a straight edge against the wheel and ground to see how adjusting tire pressure and/or rotating tires impacts this.
Frank
@SpamEggsandRice
From my 80, stock suspension. I just replaced some older stock size Michelins and they showed no unusual wear. Axle rebuild is fresh and included all new bearings.
The truck runs fine.
just use it and don't worry, unless you see unusual tire wear or steering problems. I align mine using the cord method. This is somewhat similar to what I do, that's how we used to align bomb trailers in the USAF.
@SpamEggsandRice
Yeah it's not wearing or driving irregular, so I'm just going to let it be. I've checked all the nut, bolts, etc and they are all good. I will be lifting the vehicle this weekend and replacing some worn bushing while I have it up.
The DC shaft would be needed aftrr you correct your caster by installing plates.
You need to rotate the axle by 7 degrees to fix the caster which happens to line everything up for a DC shaft
I called to order some caster plates from Dobinsons Suspension where I purchased my adjustable caster bushings. I told them what my caster is currently at and they said the bushing will work because it will correct up to 3.5 degrees. If they are wrong and I need to get the plates I can adjust the caster bushings to 0 degrees. So I guess I'll see what happens with that. I went to Carolina Driveline which is a local shop who build and service drivelines. The price for a custom DC shaft was $328 which I ordered and will be done in 1-2 business days.
Is a matter of personal preference but I had bad luck with the caster correction bushings, they didn't last, about a year of daily driving and a couple of off road trips. I went and replaced them with MOOG "OEM specs and the Man-A-Fre caster correction plates, 5 years later, the truck runs great. Just like factory suspension...
