Just had my rig aligned today and saw that my right front camber is out. What would cause that on a solid axle and is there a way to correct it. It's not causing any abnormal tire wear or anything, but I was just curious.
How are your front control arm bushings?
Loose wheel bearing?
Wheel bearings may be good but your axle nut might have loosened up. Have you jacked up the front and checked for play in the top/bottom of the wheel assy?
Another thought, check the nuts on the lower steering arm. These things have loosened up to the point where the knuckle will fall off. I'd do this before driving the truck any more.
As long as everything is tight, setup as it should be, what problem is it causing?![]()
Probably bent the axle housing doing jumps....
I had problems with mine, the problem were those bushings on the picture. The truck never ran right and they broke. Got rid of them, installed the OEM bushings and the Man-A-Fre drop arm brackets and the problem was solved.When you say "front control arm" are you referring to the radius arm like in the picture below? They are most likely the original ones that came on the vehicle.
How's the truck runs?
