alignment chaos
Round Rock
Went to NTB for 4 tires and an alignment. They said the tie rod end on PS is frozen with rust. The tech pulled so hard he pulled the passenger side ball joint out of socket on the front of the axle. I read somewhere here that the alignment is done on the tie rod on the back of the axle. Will post pics soon. Used a plumbers pipe wrench to attempt to loosen the tie rod end. Really freaking annoyed right now. They are trying to get denso replacement parts but nothing available until tomorrow. I said Toyota parts only. They are thinking only replace ball joint to finish alignment.
Notice the pipe wrench teeth marks.
Seemed to have gotten this side loose (DS front).
Question is now, do I attempt to make them take it to dealership service and pay for the repairs or trust them to replace the parts with OEM as request and install?
I can understand being annoyed, and wanting original Toyota parts. I wouldn't be upset with the tech. Stuff like that happens. And if a tie rod end is going to come apart, I'd much rather it happen while it's up on a lift than when hitting a pothole on the road or bouncing over a rock off road.
You usually have to adjust both the front and the back. The front will center the wheel and the back adjusts the toe.
Thanks and I agree that I would rather it happen in a shop. Are these parts (tie rod ends/ ball joints) something that might be in stock at a dealership? I know a certain dealership in Albuquerque probably does. I have 7 miles on it after the axle service. I don't think the pads/ rotors are completely broken in.
yup, you want that fixed well, steering is helpful ;).
Things like rust do happen, although that seems to have been some excessive pulling here. (I don't remember exactly how that bit works but is there something odd here too, like he only used one wrench instead of 2 and relied on the end to take the stress, or something slipped?) Anyway, the smarter route would have been to let you know and ask for your permission to yank hard or not, especially since that is not truly needed for alignment. They are not exactly blameless IMO.
Not intended to rub it in, but for the next person, I had soaked mine in PB Blaster before going for an alignment and the tech actually commented appreciatively on it.
Your tubes should be fine, I have seen much worse than that. He can heat that up now and It will come out easier. My son and I have had them stuck sooo bad we tossed them and put In new TREs and tubes. Sometimes much quicker and smarter In the long run.
BTW you have come upon a Very nice 91 L/C Keep all your origional parts If you mod IT. If you have not painted that axle housing and front end parts, You have a VERY Clean undercarriage...!!! Take care of your L/C, nice ones are getting hard to find...Good Job young Man..!
Alignment includes centering the steering wheel. As a former alignment guy, that kind of stuff happens rarely, but it happens. Sometimes you have to put the 48 inch pipe wrench on it. It shows that the tie rod end was bad and needed replacement. Most shops can get tie rods delivered from their nearby parts store in 20 minutes or less. If you want some other end, you might have to wait a day or two or tow it to another shop. Note that the cost of a generic rod end is probably less than towing. The only kind of tie rod ends I ever installed were whatever our local supplier could get to us right away. They never came back with problems.
I always get a kick out of it when i take my rig to a shop, to be aligned, and they tell me they cant do it due to frozen/rusted parts. That clues me in that they dont know what theyre doing, or they want the extra labor $
I gave up paying for alignments years ago. Heat, string, and a tape measure gets me close enough.
Update. I just got a call from the NTB manager and he said they tried to remove the tie rod end after using PBR etc and a torch. But could not get the TRE loose. His mechanic is saying that tie rod and tube are toast and need to be replaced. Toyota is nationally back ordered for the parts. The manager said sometime this week or something.
I need some advice. It is looking like a week or more to wait on parts. I am not keen on leaving it at their shop. I am concerned that they are going to start wanting to charge me for parts and labor "since it was fused." I would rather order parts and replace myself than have them continue to break parts.
it being fused does not excuse them breaking things. If it's really fused and there is a good possibility of breakage you don't do anything without calling the customer IMO. I don't understand how that ball could have popped off if they used 2 wrenches properly. Or what am I missing?
Thank you, it is 7 miles out of the front axle service. I finished it Saturday. I did paint the knuckles when i had it apart.
There are a few reasons it might pop off. The rod end might have been too worn, the force needed to turn the rod exceeded strength of the rod end or a combination of the two. It isn't that easy to get two wrenches on it because you really need three: One to turn the rod and two to hold each rod end. You have to bust loose the threads both ends to get it to turn when it is installed.
This kind of stuff comes into the shop from time to time and is more frequent in the rust belt than in sunny CA. The drill is you explain the options to the customer and have them make the choice and sign off on what ever they want to do before you use extreme force.
Well for now I emailed the local Land cruiser shop to see if he has any in stock, and Cdan to see what the the replacement parts are from him. At least he would know if the relay rod was really back ordered nationally or if they are just trying to get me to accept cheaper parts.
If i just replace the whole thing myself (if i had them tow it to my house) is it a pretty simple job? It looks straight forward on the FSM page. It looks like you need a puller to get the bolt off and remove from the steering knuckle arm? How about to put it back together?
I spent an hour or two on each of the tie-rods to get them freed up when I wanted to get the alignment checked. The alignment guy i went to said it happened all the time on these vehicles. He was very happy to have everything new to adjust. I ended up alternately heating them up with a torch and soaking them several times with Deep Creep. It was not real fun, but they eventually broke loose. The place to heat is about an in or so past the end of the split.
Thanks. I am picking it up with a wrecker tonight. They ordered the replacement TRE from toyota supposedly. I will go back tomorrow to pick it up. They ordered all the other parts for the steering too and wanted my to pay for them to the tune of $700 plus. I will take inventory and at least get things loose after I order from CruiserDan.
I don't know where I would be without this forum and all the great posters and vendors. This site is awesome.
I removed the tie rod from the steering arms so I could deal with it better. Rent the TRE removal tool (not the pickle fork and BFH) because they are easier to use and easier on the parts. You can buy one for about $20.
It took me 4 hours with a MAPP gas torch, a vise, two hammers, and a 18" pipe wrench with a 36" cheater pipe on it to get my TRE loose. MAPP gas could barely get the tube hot enough (in terms of available heat: (least) butane, propane, MAPP, Acetylene (most))
Buy the Moog TRE's from your local OReilly or NAPA. They will work VERY well, should be a few hours away, and only about $25 each. Moog is a good brand name (other than 555/Toyota)
Even if you get them replaced, I would still recommend getting an alignment at a shop. However, I have yet to find an NTB that I would trust with ANY of my vehicles (IMO)
