alignment chaos
Cruiser Outfitters sells all 4 rod ends for $100. They are the Japanese made 555 version too. I didn't think you could get oem rod ends from Toyota without the rods. Or maybe that was the 40 series. Idk.
So I ordered the new relay rod and relay rod ends from CDan. Got the parts installed, then the steering damper would not torque down. the ball joint inside would just spin. Fortunately I was able to find an OME SD24 after several places I called were back ordered. Should be here this week.
I still want to get an alignment after the new tires and axle service. I have been soaking the tie rod and bolts behind the axle for the last couple weeks. I managed to break a clamp bolt while trying to loosen it up. How long do TRE's last in general?
