SOLD Alameda, CA / 1985 Toyota 4x4 Pick-Up. / 99K original miles
East Bay Area, CA
Year
1985
  1. Minitruck
Mileage
99800
Color
red
((Price reduction to 16,000))
Hi 'Mud
Got my FJ60 here... and since I'm making moves to a 4x4 Van instead of this, I should get her sold.
Reckon a good home could be found here, instead of in BaT (Currently awaiting submission from them).
Key Details:
2nd/3rd owner
1985 Toyota Single Cab Pickup
99.8K Original Miles
22R 2.4L Carbureted Engine
G52 5-spd Transmission
Smog 7/24/23
CARFAX confirmed condition/mileage
Engine Related:
***NEW 22R SHORTBLOCK w/in 30k miles!
Carburetor Tuned/Re-Diaphragm’d (OEM)
NGK/Denso Cap/Rotor/Plugs and Wires
New WIX Air Filter
***New CSF 3-row HD Brass Radiator
New OEM 180’c Thermostat
New Continental Hoses
New OEM Heater Core/Bypass hoses
New OEM Heater Selector Valve
LC Engineering Valve Cover Gasket / “Moons”
New Gates Alternator / Acc belts
*** New 2023 Catalytic Converter + Back OEM-Repro exhaust (CATCO Cat, Walker muffler / Tailpipe / Tip)
Transmission Related:
OEM Transmission + T-Case
New Denso clutch master and slave cyl + fluid
Chassis/Drivetrain Related:
***New OEM Power Steering (Pump, Reservoir, Steering Box, Hoses, Cooler,)
New Draglink Bush/Zerks (Moog)
New Tie Rod Ends, Relay Rod Ends (555)
New Marlin Ecoseal Knuckle Wiper Seals
New Marlin Ecoseal Inner Axle Seals
New Koyo Wheelbearings (front)
New Koyo Trunion Bearings
New CruiserOutfitters Seals throughout
New LC Engineering 3” Est. SS Brake Lines (F/R)
New Remanufactured Calipers (F)
New Yotamasters OEM Repro Brake Rotors (F)
New 80w-90 Gear Oil F/R
New OEM/Aisin Rear Brake Hardware/ Cylinders / Shoes
New TG Rear Pinion Seal
***New 2.5” Old Man Emu/ARB suspension lift
(New Dakar Series Leafs, Nitrocharger Shocks, Greasable Anti-Inversion Shackles / Axle Pins, Urethane Bushings)
Armor/Body Related:
***ARB front bumper (OE, not adapted)
X2 Hella 500 Driving Lamps w/ Amber Tint
***Custom Fab’d NWTI Rear Plate bumper w/ two tow points/clevis, LED plate lights, and Lo-Pro exhaust cut-out
Trail Gear DOM Sliders w/ 4 welded mount points
*** 30x9.5xR15 Yokohama Geolandar g003 tires (x5), mounted on OEM FJ60 / SR5 15x6” Rims. (NO rust, NO dents, balanced and true)
Electrical Related:
Hella Headlight H4 Housings w/ 55w/100w bulbs
Mil-Spec HD Battery Terminals
BlueSea 100A Breaker for Aux electrical
BlueSea 6-pin ATO Fuseblock for Aux electrical
Custom Fab’d mount with OEM Toyota holes
Uniden Bearcat 880 CB/PA Radio w/ NOAA
P/A Horn wired behind ARB Bumper
4’ Firestik Firefly Top-Load CB antenna w/ splitter for AM/FM Radio on Custom Mount
JVC Stereo w/ AUX, USB, and Bluetooth Connectivity + 4” JVC Speakers
SR5 Clock installed
L.E.D. Pulse/Flashing tail lights
Interior:
NRG 2.0 Quick-release Hub
NRG Steering wheel (330mm)
98% perfect dash underneath cover
(Single 2” tear)
OEM Bench, Door Panels, Headliner, etc. in perfect condition and uncut/modified.
All OE gauges, lights, accessories working 100%
Extra:
Tradesman Utility/Contractor Campershell
(X3 keys, cheap HF LED lights inside, Quikfist Shovel Holder)
CuStOm CuT CaRpEt
What’s wrong/ What’s it need?
  • Paint has scratches on Driver-side Bed, in bed. I LOVE this, but someone might not.
  • Intake Manifold heat shield rattles occasionally because of a broken front mounting bolt. Planned on going LCE anyhow, so didn't trip on it.
  • The non-OEM windshield trim has flaking black paint where P/O tried to cover the chrome. I'd just replace it.
  • 1 tail light lens has a crack in it.
  • I welded in a replacement battery tray since the original was rusted through. Cut an inner fender out at a local scrapper from a red 84' 4x4, cut it down to match, and welded it in with 75/25. Not pretty, but won't rust and holds the battery good as new.
This truck will not die.
It doesn’t overheat. It doesn’t burn, or smoke.
It doesn’t ‘barely run’ or ‘have a personality.’
It’s not a instagram queen, but is very pretty.
It’s not a Tacoma, it’s what informed their production.
It’s a fully capable 105” wheelbase solid-axle 4wd that delivers 18-20mpg highway, yet parks like a Camry, and can move a house-full of stuff, yet wheel like a 40/60 series Land Cruiser.
Happy to PM you whatever pictures, Q/A, etc. I SWEAR you won't be disappointed... this lil' Ruby is an amazing truck.
Come see it, and let's talk!
