Build AK HJ-75
Sunday morning, destination home.
What’s summer without road construction
Man, I absolutely loved going through all of these. Haven't been on mud in a bit and this is the first thing I open it up to. Absolutely amazing!
Well, that took way too long, got the rear awning mount mounted up to my Alu-Cab RTT. That awning is heavy, around 85lbs, so I figured I had better stiffen up the mounts where attached to the RTT. I put a piece of aluminum angle on the inside of the RTT to spread out the load.
Got the front mount installed. I got the awning kit from Alu-cab for their awning and the kit for the awning I got hoping to mix and match. As you can see for the rear I just used the awnings mount by itself. The front you can see the alu-cab front mount won’t work with the one from the awning I am using.
