Why not? Sure... does your fuel pump have the third leg or just 2?
The new fuel pump from City Racer has just the inlet and outlet no return.
You can test the pressure anywhere on the high side of the pump. The return line has a volume restrictor to make sure that the fuel can flow to the carb when it needs it. The return is there to prevent vapor lock by keeping the fuel moving so it can’t heat up.
I was wondering about that, because on typical marine fuel systems the return is of a lower pressure than the feed. I have a power problem, when I start up an incline my truck losses power and starts to buck, reducing acceleration sometimes takes care of it but not always. I had thought that the secondary was the problem and tried the paper clip test because I thought that the secondary (kick up) was the circuit that compensates for power demand. I have since read one of your posts saying that the secondary only operates at WOT for about ten seconds and doesn't operate during normal driving. So I thought the paper clip test failed and changed out my secondary vacuum diaphragm. Now, if I'm on a flat and hammer the accelerator I do indeed get a good surge of power, but if I do the same when the truck starts to buck it only increases the problem. I want to check the fuel pressure during the loss of power to see if it's a fuel delivery issue. New fuel tank and lines last January, new filter and new fuel pump this January. So I was going to rig up a fuel pressure gauge to come into the cab so I could monitor it, but now it doesn't seem like a very safe way with a pressurized fuel line coming into the cab.
I have new spark plugs and ignition coil on order to take out the possibility that there is an engine misfire issue. While the driveability
is suffering I really enjoy this because from always shying away from carburetors I'm now getting right into it. I would like to find an in depth description about the function of an Aisan Carb.
So, if I'm having a loss of power with good fuel pressure and since the secondary doesn't function until WOT, it would indicate that the primary circuit has a problem, what could that be? Accelerator pump? Power piston? What would happen if the secondary throttle plate is opening too early? My truck is a 78 FJ40 2F and I believe I have installed a 21100-61100 (CDN) carb on the truck with no smog. I'm slowly rebuilding a 77 FJ40 2F 21100-61023 carburetor for a spare.
Any help or suggestions will be appreciated!
