I'm switching from a Rochester(PO installed) 2BBL carb back to a stock Aisan carb- on my '75 FJ40- and I'm not sure how to connect the fuel line and the return to the stock carb. The Rochester didn't use a return at all so it was plugged (by the PO) and the fittings for the intake and return are a totally different, threaded, style than the slip-on and clamp method the Rochester used.
What is the best way to connect the 5/16" fuel line to those threaded fittings and where can I find the parts? Does anyone know what the size is of the intake/return fittings on a stock Aisan carb for a '75 and what the threading is- i.e. threads per inch, "coarse" or "fine?"
If it's adviseable/better to switch to some hard lines, is it possible to buy them pre-bent? Suggestions on WHERE to buy them?
Thanks, in advance, for any help/advice!
Nick
Nick
