Air Shocks.............
Essex, Vermont
Hi,
Yesterday I was talking to a couple good friends of mine, and we got around to talking about trucks. They were talking about this "air shock" and all you do is pump air into these shocks and it gives you more clearence in your wheel well. Is this frowned upon and can you drive long distances with the shocks pumped up?
Thanks,
John
What kind of vehicle are you thinking of installing these onto?
Well, I had used air shocks on another vehicle since the stock front springs were completely flat. That was only to stop the front end from hitting the rubber stops when driving over road dots.
I would NOT recommend them just to gain clearance, as it will be way too stiff of a ride, and therefore not worth it. Then, you would lose all articulation, as they are designed for heavy load-bearing vehicles.
If this is going on a large truck, and you need it for towing, I would consider it.
Yes, you can drive long distances, but who would want to?
If this is for an FJ40, I would not even attempt it. Get aftermarket springs instead. Trying to go against the flattened arch of springs, for example, only creates more stress and load on the air shocks, making it difficult to bring them to, let's say, 180PSI.
Hope this helps...
i had a set on the rear of an '84 two wheel hiux. with 100ish psi in them i "gained" something like 2 inches of "lift". it rode like crap but i could get rubber in the first 3 gears:D
it was great for "parking" sessions as well. the thing would'nt bounce around so much, really gave you some thing to "lean" into:grinpimp: ...
God, I miss "parking" :)
i have heard of a style of air shock that will let you articulate that uses a link between the to so when you press one side up it will press the other side down but are not ment for ride hight just to help maxx out droop in your springs
not to highjack the thread but I was thinking of putting one air bag in the center(rear) 1 single bag has anyone seen something like that before ??
since I put in a tire rack I lost a bit of lift but it's riding much softer I am thinking the bag will level the 40 and maybe soften the ride even more by relieving the load from the springs and by being in the center of the differential
I can still get full articulation
any thoughts?
When I was in college the topic came up. My instructor mentioned that the shock absorber mounts were never intended to hold the weight of the car/truck/bus. For that reason, he'd seem several shock mounts torn from the rig. Just my my .02.
