Hello,
I am using a refrigerated gizmo,Hankinson craigs list special, $300.00. If you go with the desiccant and run a bead blaster or anything with a high flow, you will spend lots on desiccant filters. I use the reefer model and it works well for the paint and plasma cutter. I use another filter desiccant unit for the plasma in addition to the reefer. I had a buddy pick up a plasma cutter, I told him to use a high quality filter drier, he didn't, his plasma torch head cracked like crazy from the moisture hitting the plasma and explosively expanding and blowing the torch apart. Moral of the story, don't skimp on the equipment.
Hola
eric
