Let's try and isolate the A/C system and see if it's actually working. With the engine and A/C turned on, feel the larger of of the two pipes running into the firewall that go to the evaporator, they'll be the aluminum ones-not the rubber ones. If that pipe is cold to the touch, then the A/C is working, and the problem is most likely in the dash (the blend door stuck) or the heater valve not shutting off the flow of hot water. If the pipe is warm or hot, the the A/C isn't working and more troubleshooting will be required.
As far as counterfeit refrigerant, yes it's out there. We've heard of a bunch of R134 that came in from China that had a bunch of particulates (dirt) in it-enough to plug up the system. We've also seen R12 from Mexico that was R134/R22 and propane or butane in the cans. So yes it can be a problem. If you determine that the A/C isn't functioning, you'll probably need gauges to help diagnose what's happening. It could have leaked out some R134, the expansion block could be bad, there are a number of possibilities. Did the problems with the A/C correspond with the replacement of the radiator? When refrigerant was really expensive, we'd see shops do repairs and steal the refrigerant. Now that R134 is really cheap, we don't see that happen any more.
Sorry I can't be more specific, but this gives you some things to check.
Good luck,
Rex
