I have a Puma that I bought b/c its a great compressor for the buck but I never used it. Its for sale too!
Fail, they didn't test the Puma or Tsunami, the best bang for the buck compressors available. Likely because they would have smoked the higher $$$ compressors from Scotty's sponsors?
... Even the MV-50 had supply challenges and frequent failures at the time. ...
Looks like the Puma compressor/motor unit is very similar to the extremeair tested. Found this link that seems to help identify all the puma/extreme air clones. The Horn and Whistle Board • View topic - High Capacity 12V compressors
The biggest difference is the Puma is 1/2 the price of the Extremeair and comes with controls and tank. Seem like a no-brainier
I have also owned a Puma since 2007 not sure why the claim they were not readily available. I agree with Tools after reading OJ article it would have embarrassed the big dollar name brands.
Since 2007 I have aired up 100's of tires and ran the Puma recently for 4 1/2 hours non-stop using air tools to disassemble a vehicle.
I would agree that the Puma seems like a good value. I was mostly stating that I think it's fair to consider the testing results from the extremeair to be interchangeable with the Puma. If they're the same, it's basically as if the Puma was tested - so it's pretty easy to compare the puma performance to the other models tested.
(I have a York in my 40, which is the obvious choice for an fj40 because they are so simple to set up. I also had a York in my mini-truck - much tighter fit, but there weren't many good 12v options back in late 90's. Now there are a lot of options. If I had it to do over again with that truck I would just buy something like the Puma and hard mount it in its own side skirt drawer in the flatbed. )
Phil what is the spec of the air tools you run with the puma.thx
Reviving a super old thread. They're not quite interchangeable. The normal extreme air and Puma might be the same compressor. But OJ tested the extreme air Magnum which is 1.5hp. The Puma is .75hp or 1-hp peak.
