SOLD Air cleaner and throttle linkage rod for '73 FJ40
Louisiana
  1. 40 Series
Trying to assemble pieces to ditch the current Weber set-up and get back to stock on a '73 FJ40. I have the carb, bellcrank, throttle & choke cables from the PO but am missing the proper air cleaner assembly and throttle linkage rod between the bellcrank and carb. Located in Portland, ME but good with shipping too.
Post pictures and/or model numbers of what you’re looking for.
That said, have you looked at the classified ads here? There was an air cleaner posted earlier this week that I think fits the bill.
I have these two..I think the version with heat riser is from a 74?
I have the mounts as well if needed
Looks like I found an air cleaner. Thanks for the leads. For the throttle linkage rod, this is the part I'm looking for - connects the ball on the bell crank to the ball on carb. Think it's a specific length for the oddball '73 linkage so I'm working on making my own but wanted to see if anyone had the specific part lying around that I could put to use.
