GTV
- Thread starter
- #21
@GTV why not just learn/document the reindexing process and keep the tools/process printout in your car? I wouldn't do it ahead of time, but I do think knowing how to do so in the field is smart. Prepare for failure, but don't plan your life assuming it's all going to go wrong, haha.
I will learn the process by doing it, likely within the next day or two hence why I posed the question. I've got a par of OME reinforcement brackets to install (probably not needed for my use but they're cheap insurance) and my adjusters aren't equal from side to side so I figured I might as well balance them out and give them a couple clicks at the same time. I keep a 30mm socket on board and an assortment of metric tools, of course.
If the AHC gives up you are on bump stops and that's it. The stock torsion bars would have to be reindexed to unsafe levels to be able to even slightly lift the vehicle above the bump stops, if possible at all.
Maybe so, do you have a better idea?
The Strutmasters (AHC elimination) kit uses the stock AHC t-bars but specifies to re-clock them by 2 splines. I'm not recommending this kit, I'm just saying it can kinda support a stock weighted 100.
If somebody wanted to be ultra prepared, I'd say a 30mm socket and pre-installed Timbren or Wheeler Bumpstops front and rear would be part of the plan.
I think most common AHC failure is the AHC sensors. Three connectors with the "right" resistor that tricks the system into thinking all is fine and dandy would be cheap and helpful. I have not tested this theory though.
In my 20 yrs of ownership, I've had one AHC failure, 600 miles from home but I was able tinker with it and made it home without issue. It was an AHC sensor failure. When I got home, I disconnected the "bad" sensor and drove around town. Except for the blinking light, it was fine. The rear only has one sensor. So, if anything, a spare rear sensor would be most helpful.
I should perhaps test these theories further.... but maybe somebody else can!![]()
The Strutmasters kit is a good point. "Kinda" supporting the weight is better than nothing at all.
Good idea on the aftermarket bump stops. I haven't researched them much but I imagine with the very slight sensor lift that I'm running (3/4") I'd be on the bumps all the time(?)
I keep 3 extra height sensors on board. I learned that lesson on day #1 of ownership. Mine was sky high with them connected and on the floor disconnected. Miserable ride quality either way and it wasted the front tires in 600 miles. Tricking the system with resistors is a clever idea...
