Hello Rmarque,
Here's the simple version of what you need to do.
Buy a Techstream cable off of Amazon or similar.
Buy an older laptop (Windows 10).
Follow the instructions on the 1st few pages of this thread to get Techstream working.
Getting Techstream up and running can be a bit of a pain. Hopefully this helps someone get started quickly.
Step 1: Purchase an OBD-II / Mini-VCI interface.
- I have sold out of my cables and supply chains are back in order, so no reason to purchase more. Anything like this will work:
Mini-VCI cable on eBay
Step 2: Download Hypervisor
- Windows / Intel Mac [Download Virtualbox]
After you've gotten Techstream up and running, do the following checks...
AHC Height Check
Check Height at Normal Height at All 4 Corners (Level Ground, SUV Running):
- Front should be 19.75” Hub Center to Fender
- Rear should be 20.5” Hub Center to Fender
Adjust Torsion Bars to get the Front Cross Level
1 Complete (360 Degree) Turn on 1 Torsion Bar Bolt will raise / lower that corner ~1/8”
The goal is less than 1/4” Difference
After the Front is Cross Level...
AHC Pressure Test
SUV with a Full Tank of Gas.
SUV on Level Ground.
Disconnect Fluid Temperature Sensor (Optional…)
- On the side of the pump assembly, rear connector with 2 wires
- Center connector with 3 wires is the pressure sensor
- Forward connector with 2 heavier blue and white wires is for the pump motor
Connect the TechStream Cable to the OBDII Port under the dash.
Start Oracle VM VirtualBox.
Start TechStream.
Enter Vehicle Information.
Double Click on AHC.
Click on Data List.
***Change Vehicle Height to L.
Wait 60 Seconds.
Change Vehicle Height from L to N.
Wait 30 Seconds after N is reached.
Read Front Pressure.
Front Pressure should be 6.9 MPa.
If Front Pressure is Higher than 6.9 MPa, adjust Torsion Bars.
1 Complete (360 Degree) Turn of Both Torsion Bar Bolts will lower the Pressure by 0.2 MPa
After Adjusting Torsion Bars, Repeat Step ***.
If Front Pressure is now 6.9 MPa, the Front is Correct.
Read Rear Pressure.
Rear Pressure should be between 5.6 & 6.7 MPa
If Rear is not in Spec, purchase new rear AHC springs (i.e. 48231-6A780 / Brown) or 30mm spacers.
You only need to Install Higher Rate Rear Coil Springs (like King Springs...) if you're always carrying extra weight (like an Aftermarket Steel Rear Bumper).
Installing New Rear Coil Springs and / or Spring Spacers will not change the Rear Height of your SUV.
It will only change the Pressure in the Rear of the AHC system.
The AHC System supports part of the weight of your SUV (via Hydraulic Pressure), while the Front Torsion Bars and Rear Coil Springs support the rest of the weight of your SUV.
The more weight the Torsion Bars and Coil Springs support, the less weight the AHC has to support.
There is a happy medium as to how much weight each supports.
Note: You should also replace your AHC Fluid (if it hasn't been done recently), perform a Graduation Test (to make sure your Globes are healthy), and perform a Pump Test (to make sure your Pump is healthy).
I hope this helps.
Tom
