AHC pressures with Added weight?
Arkansas
Hi, I plan to perform pressure adjustments this evening. Currently the truck is stock with the exception of 33"s and I replaced the rear seats with a 150lb storage system. In the next two months I will be adding about 120lbs NET weight up front with TJM bumper and synthetic winch. I'll also be adding sliders with a net weight gain of 60lbs. This truck is only used for camping/hunting/overlanding, so 95% of driving will have between 350 and 450lbs of gear in the back and half of that will always stay in the truck.
I know the neutral pressure tests and adjustments require going from L to N, a full gas tank and no one in the vehicle. I should adjust until the pressure for the front is 6.9+/-0.5 MPa and rear is 5.6-6.7 MPa. But, do I need to re-do these adjustments when the weight is added and still attempt to get those pressure numbers with that extra weight?
Basically, I'm not sure if I should adjust pressures now, or wait until all the weight is added and make adjust pressures at the weight the vehicle will always be?
Yes, you'll have to readjust after the front bumper/winch/slider install. If you can't get into spec, you'll have to swap out the TB's and maybe get a spacer for the rear or get King AHC springs from Australia.
sorry, not to hijack your thread, but reading it made me think of something; has anyone ever tried stock LC rear coils and TB's on an AHC system to accommodate more weight? I assume you can get some pretty cheap since people are constantly lifting their trucks?
So, basically get it into spec now with stock weight, then after adding the additional permanent weight, re-test and crank TBs to bring into spec possibly requiring LC TBs and King Springs. Gotcha. Seems simple enough.
I'm interested to see what my pressures are considering the truck rides like a dream still with no AHC issues. It's 20 years old with 167k miles on the original AHC system.
Yup, that's what some here do. The LC rear coils have a higher spring rate than the King's if I remember right. Unless you drive around weighed down, the King's might be a better choice.
Non AHC springs and TBs aren't meant to be used with AHC system, there's too much resistance in the two and will not work properly.
OP i had success with my AHC in the rear with using a 30mm coil spacers, that brought my pressures down to 7mpa and within spec, the front just crank the TB clockwise 8-9 times and read pressures again. I was pretty loaded for my trip, 150lbs dry cargo system, 200lbs of food water and gear in the rear, as well as fuel tank on top of roof rack and a 100lbs spare tire. I had no issues lowering and raising it
Yes, from what I've read I should be able to bring stock TBs into spec by cranking them. The rear may be more difficult, but I would go with the King Springs that are made for the AHC system rather than LC springs. But the coil spacer may work better possibly? Where would I find 30mm coil spacers and any idea the cost?
I bought my spring spacers here:
Slee Offroad
So those spacers say they are designed to add lift to the truck. Are these actually lifting the LX or are have my old springs lost their ability to lift and the spacer just get's it back to the height it was at when new?
They provide more strength for the rear sagging coils by adding more preload. They don’t really lift it, maybe a couple mill, when I skimmed mine I didn’t get any lift out of it just made the rear springs stronger
Hey FxFormat same question but only adding ARB bull bar, can I just crank the TB without touching the rear spring and bring the
pressure to spec? If so, how many time do I need to crank it? Like 4-5 times will that be enough and not adding winch.
I have a 2007 Land Cruiser.
You need to get neutral pressures reading before you start cranking things, but per my experience, 4 turns clockwise equate to 1mpa of pressure drop. Hook up techstream or a high end scanner that can read AHC pressures, load up all the stuff you plan on carrying, then put the truck in low, then to neutral, and then check the reading.
Current pressures with nearly full tank of gas and standing outside the car after going from L back to N.
I’m surprised at how perfect these pressures are with 20 years and 167k miles. Makes me wonder if these globes were replaced by the first owner and not documented. There are 60k missing miles of dealer service from 85k to 145k. Is it possible for these to be original with these pressure readings?
I assume these pressures are low enough that I may be able to add my bumper, winch, sliders and gear in the back without going over spec and possibly just need a few cranks of the TBs.
Needing some input. My LX is only use for camping trips and thus, 90% of it's use is loaded out with about 350lbs of gear (14 gal water, camp gear, large cooler, food, passengers gear, hi-lift etc...). I just added a TJM front bumper and winch with syn. line and 5 turns of the torsion bars brought me well within spec: Front 6.9 and Rear 6.4 with a full tank and empty truck. BUT, once I've added my gear to the back and filled up the water tanks and cooler, I'm at Front 7.0 and Rear 7.9.
My question is, should I be trying to get my LX rear in spec the way it will normally be driven with all the gear as I would consider this the normal weight of the vehicle when in use without any passengers? If so, I either need to swap to Kings Springs in the rear or add rear coil 30mm spacers. Will either of those options bring my rear down within spec?
I think the recommendation from the really experienced AHC users would be to set up the ride for your loaded condition. Based on your description of 90% use in a loaded manner, that is what I would do. I don't know if spacers alone will drop you low enough on the pressure. The King Springs will most likely be needed.
If you do a search on King Springs, there is a thread that has a lot of info.
(edit) - Link king-springs-ahc - additional links within the thread.
Definitely go with King Springs. With all the gear loaded, you might even need spacers in addition, for the duration of a fully loaded trip. Use TechStream / Tester whenever you change the permanent weight.
The advantage of changing to stronger springs instead of just spacers, is that you get the benefit of a longer, more linear, suspension travel. With spacers you put more load on the already overloaded coils.
Changing globes will do nothing to the pressure. The globes are your gas springs which are being put under more load the heavier the truck is and the weaker the coils and TBs are. As the globes also loose their gas pressure over time, they will in the end bottom out and need replacement. The pressure equals the weight of the truck minus what the coils and TBs can lift.
The globes can even be removed (and replaced by a cap) and the pressure will still be the same, just that you will not have any suspension travel anymore.
Adding spacers, cranking TBs or changing coils will never lift an AHC truck as long as you don't go with springs that are so strong that the AHC looses all pressure. As long as you go with springs and spacers that keep the ahc pressure within or around spec, you will never change the height. Only the ahc system will decide the height, and it is set according to the signals from the height sensors.
Additional info:
The reason for keeping the pressure within specs is that the AHC system is also your damping, the function which is done by the shock absorbers with a conventional suspension system. The damping is done on the ahc fluid as it travels through the valves in the actuators when moving between the "shocks" and the globes. If the pressure gets too low, there isn't enough force on the fluid to give you any damping, making the truck very difficult to handle. If the pressure gets too high, it won't be able to lift you to Hi, or even to N if you load it too much.
Most threads on AHC discuss only the automatically height control, and not the TEMS part of AHC/TEMS. The TEMS damping is more advanced than the ahc part of the system, and something which is quite unique, with it's 16 step continuously adjusting damping, adopting to road conditions, vehicle movement and driver input. It's for the functioning of the TEMS damping that it is important to keep the ahc pressure within specs.
Sorry for the long post - just felt that it could help you getting the most out of your truck, as it seems like you enjoy using it fully (as opposed to most of us with mall cruisers).
Ok this is such helpful information. I had pretty much decided on spacers as a few other threads indicated that 30mm spacers would drop my rear by about 2mpa which would get me within spec. This is also an inexpensive fix.
will Kings springs drop the MPs even lower? Would I risk making the truck undrivable if driven unloaded?
