AHC not bleeding.
Uk Suffolk.
Hi Guys,
just replace the two rear feed pipes to the rear shocks/rams.
Have pressure at the two from bleed nipples and accumulator, nothing from the rears.
Light flashes from L to N but no fluid from the bleed rear nipples.
at a pals work shop with only phone internet access.
Any pointers. ?
Thanks.
Db.
I assume rear worked before you pulled lines and pump is now running also. So likely air in line and/or shock. You could try jacking up rear, then open both rear bleeders, then lower (with jack) vehicle all the way, close bleeders and start vehicle. Just let it sit and idle for few minutes with all doors closed. Make sure to not let reservoir get to low or it will suck air. Repeat a few times if need to.
If pump not running, activate through tech stream in test mode.
