AHC Neutral Pressure Adjustment
San Diego
So I got around to adjusting my AHC neutral pressures today as I finally have everything I needed to do this.
I have an '06 LX470 with 72k miles.
Using a Mini VCI cable with Techstream software (purchased here - http://www.uobd2.com/wholesale/mini-vci-for-toyota-tis-techstream-v500028-single-cable-2442.html) I was able to read my current neutral pressures from the AHC ECU:
Before Pressure - 7.5 MPa Front / 6.8 MPa Rear
Spec calls for 6.9+/-0.5 MPa front and 5.6-6.7 MPa rear. You can see after 6 years, the pressures are just out of spec. This means that the AHC system is shouldering more load than optimal. It also is reducing the load carrying capacity and ability to go into high clearance mode when loaded. That's why it's so important to have the pressures in spec to both preserve the AHC system and ensure that the vehicle can perform when loaded.
So now is where my take is a bit different. Instead of replacing the rear springs, I opted to get a set of trim packers for the rear springs to basically, pre-load them to account for the settling. The spacers are to springs what cranking is to torsion bars.
Trim packers specific to the hundy aren't readily available. I figured since 80 series springs can drop in, their trim packers can be used as well which was the case. Without an existing knowledge base on this, I bought 5mm trim packers (http://man-a-fre.com/parts_accessories/Trim Packers.htm). Go for 10mm trim packers for anyone else doing this from the same link.
You'll also need spring compressors to install. I used these - http://www.harborfreight.com/macpherson-strut-spring-compressor-set-3980.html
With AHC set to high, I lifted one rear corner of the vehicle with a hydraulic floor jack on the frame and set a jack stand. The idea is to get as much pre-load off the spring. Then working one corner at a time, compress the spring on car with the spring compressor. Slip in the trim packer when there's enough space.
With only rear trim packers - 7.3 MPa Front / 6.7 MPa Rear
A good change, but should have went with the 10mm packers! The AHC rear spring are quite tender as you can see in the pic. Hopefully by adjusting the fronts, I'll see a positive change the rear too.
After cranking the front torsions 3 full turns driver side, and 2.75 turns right (left height sensor showed incrementally more sagging:
Cranked and trim packers - 6.7 MPa Front / 6.6 MPa Rear
Spec - 6.9+/-0.5 MPa Front / 5.6-6.7 MPa Rear
Really wish I got the 10mm trim packers but I'm in good shape for now. Project costed me all of around $70. :beer: :steer:
Thread revival! Did you need to remove the tire or did you simply lift squeeze in there compress and switch?
I would say the removing the tyre will give you more room to move. Otherwise it will be a tight squeeze.
Have never tried it on AHC. Perhaps the higher shock pressure negates disconnecting the lower shock mount, but one typically only needs to pull out the lower shock bolt and lower the axle to get the springs out (or add a puck). Get the frame up on stands and control axle droop with your floor jack, wheel off.
No need for shock disconnect on AHC...but you do need to remove the wheel to allow the axle to droop. With the proper spring compressor, it shouldn't be a problem at all to compress the springs and install the spacer. The AHC springs are really, really "pliable" compared to a traditional spring. I actually ended up letting the axle droop and compressing the spring with a tie down strap...wouldn't recommend that to anyone, but just saying with the proper spring compressor rented from your favorite auto parts store, it shouldn't be an issue with just letting the spring decompress as much as it can with the frame on a jack stand and then compressing it and stuffing the spacer in there...
So when replacing the AHC spring with a non-AHC a spring compressor might be the best way to go as well.
Ordering springs right now through Cruiser Outfitters as we speak. Will update in my post on MPa changes and lift total.
