AHC mini lift
Old thread, I know but I'm looking to do the same with mine. However, as my LX (recently purchased 05 w/ahc) will be used for HWY travel, more than trail, I am looking for .5-.60' gain in the front, not a level out. Not sure which method to take: adjust sensors, then TB's; adjust sensors only or any other method? With the small amount of lift (basically to support droop with TJM) is there a pressure issue? The AHC really throws me for a loop. Purchased this for more of a daily driver. I really like the AHC as it allows for extra height, when needed, while retaining MPG for highway travel. only 120k miles and the AHC checked out perfect so ripping it out, at this point, would be heavy on the pocket book. Any expertise would be great!
Guess my PM didn't help much.. sorry.
Have you read this thread:
2-2.5" AHC Lift Using King Coils & Shock Spacers
Or any of the many AHC threads? I suggest you learn more about the system. Two things affect pressure, age and height. Your pressures are most likely out of spec already due to the sagging nature of spring steel from age. I would read the threads about techstream, get a copy, and figure out where your pressures are at. Then you can decide what you want to do lift wise.
